Rinehart TD Questions
Old Sep 19, 2006 | 12:02 AM
FLHX's Avatar
FLHX
Default Rinehart TD Questions
I'm really close to pulling the trigger on a set of Rineharts True Duals for my SG, but I have some questions.
A friend of mine put some on his Road King over a year ago. So I know he has the older style. The left pipe seems to stick out a little further than the stock pipe. I was wondering if the new Rineharts (#1800-0242) have the same issue. I know they redesigned the mufflers, baffles and mounting bracket.
With the stock pipes, the left side passenger footpeg on my SG comes really close to hitting the exhaust when it's in the up position. There's only about 1/4" gap between the peg and the pipe. So if I get the Rineharts, will they hit?
I have seem some ads for Rineharts stating the passenger foot peg needs to be repositioned. Again is that just for the old style?
Or is this no longer an issue with the new style.
Old Sep 19, 2006 | 12:10 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Rinehart TD Questions
have had mine bout 19 months, didnt have to change locations on anything, didnt connect the brace, and have had no problems. they do stick out more than the stock ones, but i personally like it that way. good luck with yours!
Old Sep 19, 2006 | 08:46 PM
FLHX's Avatar
FLHX
Any SG owners out there got some input?
Old Sep 19, 2006 | 08:50 PM
bountyhunter's Avatar
bountyhunter
Go with Hard Krome....NO CLAMPS! Wicked sound, style, engineering and performance. Take a look...and decide.
Old Sep 19, 2006 | 09:01 PM
eddybo69's Avatar
eddybo69
Ordered mine just a few minutes ago.....too bad they will not be here until they are released in Oct.
ORIGINAL: bountyhunter
Old Sep 19, 2006 | 09:17 PM
Bryan TTM's Avatar
Bryan TTM
eddybo...get last years model and have a bung welded in....man i like your bike
Old Sep 19, 2006 | 10:27 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Go with the Rineharts. Their customer service is fantastic. I have the old style and my rear header finally broke at the bracket that used to connect to the starter bracket. No problem getting a replacement. You have to put spacers (supplied by Rinehart) on the right rider floorboard to move it out just a little. No problem at all with the passenger floor boards. The quality of mine (except for the welded bracket) has been great. The chrome has held up really well an no discoloring.
Old Sep 19, 2006 | 11:26 PM
waffler's Avatar
waffler
I put rineharts on my 06 SG and heres what problems I had: The front head pipe was so close to the timing cover that you couldn't fit a piece of paper between it and the pipe. On your passenger pegs you will have to move it up (1) hole. Not a problem.
as far as the front head pipe goes I called bub customer service and they sent me a new front pipe out with a call tag to send the other one back. Take a look around and you'll see a lot of front head pipes hitting or too close. Overall they look and soung great. Good luck
Old Sep 20, 2006 | 05:43 AM
DI75's Avatar
DI75
I have had both. No comparision T-REX RULES!!!
Old Sep 20, 2006 | 10:51 AM
Branded's Avatar
Branded
I have Rineharts on both my bikes. No issues here.
