May as well break it on on the Dyno where the operator can monitor afr & temps during the process.
You can do far more damage riding an untuned motor for "x" miles than would occur in the hands of a competent tuner on a Dyno.
If you don't get the rings properly seated right from the start, you may never get the seal you could have....
But, WTF do I know...????.....
Quite a bit. The fxd after 3000 pic is proper ring seal, nice and clean, done on the dyno. The bad ring seal pic is something you cannot get back. On the dyno you can see heat and afr's. Takes 20 mins to break it in and then start the tune.
When we get done with a build, we put a break in MAP and put the bike on the dyno and check A/F at idle, cruising etc. Make sure it's running a tad rich all the way around. Then we turn the rev limiter down and take it for a ride. Then hand it over and tell the customer to break it in and we'll see them in 1000 miles. Been working just fine for us for alot of years. Our shops been building race motors since the early 60's, got a land speed record at Bonneville in '65 and tons of flat track titles in the family.
Very close to what my indy does except he puts a mark on the throttle and tells you not to go past it in any gear. Come back in 500 miles.
That's all fine, if the guy doesn't go past the mark. Since we warranty our motors and stand behind our work, we want to make sure they stay in the RPM range we want them to So the rev limiter is the answer for us.
Dangerous game, I don't care what anybody says. Your tuner took a risk with your bike "taking it to r's you'll never see" before the rings are fully seated. You got lucky, you got away with it, but it was a risk non the less. It hurts nothing to wait, yet some insist on doing it.
I didn't really consider it a "dangerous game". The HQ113 build is not an easy build to tune from what I understand. I did do 3 or 4 ring seating runs with the starter map, but the motor was sputtering and running poorly. The tuner also ran the bike on the dyno for the first 20 minutes and did some ring seating runs. He then tuned the lower rpms, and then at the very end tuned the higher rpms. 30 miles on the bike to tune it versus 1000 miles with a poor tune. I am willing to bet that the 1000 miles with a poor tune would have done more damage to the engine than the 30 miles on the dyno could have. With the starter map, one cylinder was way rich and one cylinder was way lean. Who knows what would have happened if the bike was run like that for 1000 miles.
I keep hearing the "poor tune" argument. All you need is a base map that's close. If you are uncomfortable with that, then put a sniffer on it at low rpm's, touch it up if you have to. I never said anything about blindly running 1000 miles with a big build and a stock ecm. Never.
That's exactly what we do. When I said we run an air fuel check on our base MAP we do a "quickie" tune in the lower RPM's and set it rich, then lower the rev limit and let them have it to break in. When it's broke in the lower RPM's are pretty close to being tuned, as far as A/F goes, so we raise the limiter and do the full tune. Never had a problem. I don't see the arguement about breaking an engine in with a poor MAP. If the builder / tuner isn't willing to verify his break in MAP is go and make the adjustments to make it good then in my opinion it's just lazyness on the tuners part. But like I said, that's just my opinion.
Ed,
It wasn't a stock ecm. It was a SEPST "starter" map for an HQ113 that the tuner has used before. In fact, it's his start map that he uses to tune every HQ113. It still wasn't good enough to do any real miles on. If breaking in on the dyno was so bad, then why don't we hear horror stories about it? Would any competent tuner risk a bike breaking down on the dyno if breaking in on the dyno was risky? My tuner said that he does dyno break-ins all the time. The search that I did before deciding to break in the dyno didn't reveal any horror stories either. I understand that you are passionate about your beliefs, but I broke my bike in on the dyno, and the bike runs strong and makes the power advertised with my pipes. There are alot of people that break bikes in on the dyno, and if it causes any damage, then I'm sure that we would have heard about it by now. I am confident that I made the right choice. You are certainly entitled to your opinion, but if you can't provide real evidence that breaking in on the dyno somehow causes damage or decrease longevity of the engine, then it is just that..... your opinion.
That is precisely what I try to avoid.
Too fat is far worse than too lean (despite urban legend) because it can and will wash the rings out, wash the oil from the cylinder walls, and contaminate the oil.
But that's just me.
How others do it is totally up to them. What ever floats one's boat. To my, all that matters are the motors I build and/or own.
