Problem with Rider Backrest Pad
Old Nov 3, 2010 | 12:46 PM
TxCowboy's Avatar
TxCowboy
Default Problem with Rider Backrest Pad
Need to remove the Rider Backrest Pad (Comfort Stitch, 52572-09A) so that I can access the battery area.
How do you do that?
I thought I would just be able to pull up on the backrest and remove it but it's stuck tight. What am I doing wrong?
Old Nov 3, 2010 | 12:51 PM
xdanman's Avatar
xdanman
Default re
Sqeeze it together, it is spring loaded.
Old Nov 3, 2010 | 12:55 PM
Iceman24's Avatar
Iceman24
Yep, squeeze the two rods toward each other & pull up - should come off.
TxCowboy's Avatar
TxCowboy
OK, that's what I thought and what I remember from my last bike.
Gonna have to break out the pipe wrench to get this one off....
Old Nov 3, 2010 | 12:58 PM
tankplunkett's Avatar
tankplunkett
Make sure that your not pulling both rods to one side, if you do it can still hang up. Make sure your squeezing both rods to the center.
Old Nov 3, 2010 | 01:05 PM
TxCowboy's Avatar
TxCowboy
Finally got it out. My hand is almost too big to push down into that space far enough to push the ends together but I was finally successful.
Say, what's the little pigtail thingy attached to the battery? Is that for a battery tender or is that just a 12v dc accessory plug?
Old Nov 3, 2010 | 01:07 PM
upstate tim's Avatar
upstate tim
The deeper you can get your hand down the seat opening the easier it is to squeeze
Sounds like ****....
upstate tim
Battery tender
Old Nov 3, 2010 | 01:09 PM
TxCowboy's Avatar
TxCowboy
Yep, that's what I thought too. Thanks, all!
Iceman24's Avatar
Iceman24
Originally Posted by TxCowboy
Finally got it out. My hand is almost too big to push down into that space far enough to get push the ends together but I was finally successful.
If it looks like this - it's for a tender.
