Lifter Bleed Down...What exactly is it?
My dealer suspects my lifters are bleeding down causing my reported cold engine clatter.
Question: Could bad lifters be the cause of pinging when the engine is hot?
I thought maybe the lifters would fix that as well as the clatter, but I guess not.
I was also thinking about adding TMan 555 cams while they were at it but at this point I wonder what shape my pistons are in.
IIRC from your previous posts, you ride a TC88? If so, and it is a pre '05 model, the valve springs won't accommodate the higher lift of the TMan 555; or later, no worries, but the Andrews 48 would be a better fit IMHO. If a pre '05 model, the Andrews 21 or 26 are the go to cams; 21 for naggers or 26 for softails and dynas.
I had my stock lifters replaced under warranty last year. Cold startup clattering solved.
Then, this spring, I got a 107 done by FM, pistons showed no signs of pinging. What I was hearing was valve train noise.
Jamie uses Woods lifters, so they were replaced again with the build in the spring.
But now, after about 8K miles on my 107 build (just back from Sturgis), its making a hellish clatter on cold startup, I actually have to ride it a couple miles to make it go away.
Recommendation from Jamie is to put another 1/2 turn pre-load on the pushrods.
To complicate matters, the service manager at my local dealer wont touch it, but the service writer, a former mechanic and very familiar with Woods products, offered to adjust it before hours on Wednesday. Fun fun fun.
It always clacked loudly at startup, and some times even got loud during regular driving. I though my engine was toast.
It would take 5 minutes for it to quiet down at startup, it was this way for over a year,
always loud at startup. I dumped 1/2 can in the oil, and on the first start it started to quiet down. Then running it for another 10 miles totally quieted it down. Next day cold start, the noise was GONE, for the first time in a year I started the truck with NO lifter noise.
Now, people call this stuff snake oil, whatever, I heard the results with my own ears.
Ran the truck for 50 miles, dumped the oil, and it was black as tar.
The truck never made any lifter noise after that one treatment.
Before that, I was ready to sell the truck, it was that bad.
The stuff works great for sticky lifters, did the same for a friends truck too.
