2008 ultra compression release question
Old Nov 4, 2010 | 06:11 AM
denman's Avatar
denman
Default 2008 ultra compression release question
I have a 08 ultra. Am going to do a 103 build this winter. I picked up some stock 103 heads with automatic compression releases, wire harness and every thing. My question is when I hook up the harness for the acr will they work, or does something have to be turned on the Ecm. I am useing a pcv from fuelmoto for my tuner. This is a good question for Dawg.
Old Nov 5, 2010 | 04:30 AM
denman's Avatar
denman
Ok fellas some one must have an answer to this,
Old Nov 5, 2010 | 06:20 AM
imrotton2's Avatar
imrotton2
i think they should open with the starter switch. and close when switch is released.
i got manual releases
Old Nov 5, 2010 | 06:50 AM
Jim Dawson's Avatar
Jim Dawson
I have the same setup but using the TTS tuner (converted from my SERT). I had to turn the ACRs on with the TTS software. I'm sure a dealer can turn them on with their equipment.
I guess the short answer to your question is - yes, they must be turned on in the ECM.
Old Nov 6, 2010 | 04:15 AM
denman's Avatar
denman
Another Question is does any one know what the default setting is on a stock 2008 ecm. for the compression release?
Apr 29, 2017 04:52 PM
RFC1962
Apr 28, 2017 06:17 AM
binundone
Apr 24, 2016 08:08 PM
RCinLaveen
Apr 30, 2014 09:45 AM
berniemc
May 20, 2012 02:25 PM
