ques on se compensator
Old Nov 5, 2010 | 06:04 PM
vailtl's Avatar
vailtl
Default ques on se compensator
I just installed se compensator. The bolt that was in kit was the same length as the original one that came out of stock comp.
It had blue lock tite.
Ques is do you use that thick spacer from stock comp on the se comp?
The bolt was to short to use with spacer.
I used that bolt without spacer bike works fine.
When I was cleaning up later I found another longer bolt about 3 5/16 long. It had white lock tight.
This bolt it appears would have worked with spacer.
I don't really want to take the cover off if I don't have to.
Thanks,
Tom
Old Nov 5, 2010 | 06:08 PM
Faast Ed's Avatar
Faast Ed
Thanks,
Tom
They had pretty clear instructions with it. I don't recall having to reuse anything at all from the stock comp. But I do recall having to be way careful not to pinch that little disk that resembles a clutch disk, that fits right behind the comp.
I will look and see if I have a copy of the instructions still.
Edit: No, you don't reuse anything. http://docs.sendsilently.com/getsile...8c75bd1e06f215
Old Nov 5, 2010 | 06:24 PM
voodoodrug's Avatar
voodoodrug
wow no way! lol
This is what I would do,had a similiar story. My clutch adjuster lock nut fell in the primary and I rode around a bit until it started to worry me so much that I broke down and pulled off the primary and retrieved it....good luck
Old Nov 5, 2010 | 06:25 PM
dawg's Avatar
dawg
HERE's the destructions
No stock spacer used here on mine
Old Nov 5, 2010 | 06:52 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Lets put it this way, if you use that washer you will have a nice crack/hole in the primary cover after a few miles. I believe it happened to a member here already......
Old Nov 5, 2010 | 06:56 PM
1flhtk4me's Avatar
1flhtk4me
I think you have some good advise here.
Do the 2011 touring bikes have this SE comp. installed already?
Old Nov 5, 2010 | 08:49 PM
dawg's Avatar
dawg
Yes..
Old Nov 6, 2010 | 07:00 AM
1flhtk4me's Avatar
1flhtk4me
Thanks Dawg.
Just wondering because the one on mine is pretty loud.
Old Nov 6, 2010 | 10:28 AM
vailtl's Avatar
vailtl
Default Thanks Guys Fixed
I took cover back off and replaced that stock bolt with the long one that I found later.
did not use spacer.
Thanks for your responce.
Someone that packs these parts through in a stock bolt.
Which really messed me up. It worked ok but could have been
a big problem down the road.
Old Nov 6, 2010 | 10:34 AM
1flhtk4me's Avatar
1flhtk4me
What are you guys using to wedge the sprockets from turning when tightening the comp bolt?
