Wheel bearing puller ?
Old Nov 11, 2010 | 07:18 PM
cooper57M's Avatar
cooper57M
I got a 25mm bearing remover from amazon for little over 30 dollars. I just bought the handle and the collet. Motion Pro manufatures it. I removed the bearing with no problems. I got the bearing installer from the below link for ten dollars. Worked like a charm.
http://www.amazon.com/s/ref=nb_sb_no...89524266&enc=1
http://www.chopperscycle.com/TOOLS-SUPPLIES/c295271/
Old Nov 11, 2010 | 10:13 PM
emwolb's Avatar
emwolb
+1 on the auto zone puller.
Old Jan 17, 2011 | 05:59 PM
sprint12's Avatar
sprint12
Originally Posted by labou1
Got one from harbor freight , used it on my front bearings and it works as good as the $$$$$$ ones
Would happen to have the harbor freight part number?
Old Dec 23, 2011 | 12:17 AM
drspencer's Avatar
drspencer
Which is more tricky/difficult, pulling or installing the bearing?
How well does Georges tool install the bearings?
Thanks
Old Dec 23, 2011 | 01:04 AM
Inspector 12's Avatar
Inspector 12
Thanks
I have George's tool, so pulling and installing the bearings is equally simple. I am sure you could pound the bearings out with a drift punch and hammer as long as you are very careful not to **** the bearing in the bore. I can imagine pounding this style of bearing into a wheel though I have read of many doing so.
Old Jul 15, 2019 | 07:53 PM
A-ARAWN's Avatar
A-ARAWN
Stage IV
[QUOTE=SpiderPig;7523024]I went to our local Autozone store and they have tools that they loan out with a deposit. They had a blind bearing puller there that worked on a wheel with 25mm bearings. I made a press with 3/4 threaded rod and some washers and bolts for the install. Worked very well for only a couple of bucks. Might check out your local Auto Parts store.[/QUOTE
Thanks I'll head over to O'Reilly's and see if they offer a comparable rental
Old Jul 16, 2019 | 09:00 AM
Spartanden's Avatar
Spartanden
I lost front bearings couple years ago. When i got home, i found a puller/installer from Pit Posse for less than $100. Bought set of rear wheel bearings and plan to change when I change next rear tire..... check out Pit Posse for pullers.....
Old Jul 17, 2019 | 07:38 PM
Zerk's Avatar
Zerk
So what bearing are you going with? Read about people being unhappy with what Harley is currently offering.
Old Jul 17, 2019 | 08:37 PM
05UltraBob's Avatar
05UltraBob
Pit Posse puller on Amazon right now for $85.00
Amazon Amazon
Old Jul 18, 2019 | 06:38 AM
decencyxdefied's Avatar
decencyxdefied
I love new members reviving an 8yo post lol, The pit posse works great. Kinda sucks having to spend that much for 5 mins of work but if ya need it ya need it.
