Wheel bearing puller ?
Old Nov 11, 2010 | 01:53 PM
DPete's Avatar
DPete
Default Wheel bearing puller ?
What works on the rear wheel, slide hammer and blind puller ? Hammer and punch?
Old Nov 11, 2010 | 02:14 PM
88racing's Avatar
88racing
This......
Georges garage also sells it cheaper.......
http://www.georges-garage.com/chassis_tools.htm
Old Nov 11, 2010 | 02:22 PM
andyp's Avatar
andyp
I bought a slide hammer puller set from Harbor freight for 40 bucks,but I havnt used it yet though.
Old Nov 11, 2010 | 02:30 PM
relli's Avatar
relli
i would think any generic bearing kit would work
Old Nov 11, 2010 | 02:47 PM
FastHarley's Avatar
FastHarley
Former Sponsor
slide hammer could pull the races out of the bearings. Georges is cheaper than the other by around $75~$100.
Old Nov 11, 2010 | 04:14 PM
Inspector 12's Avatar
Inspector 12
I bought the George's garage kit, it is an excellent product and made in the USA
Old Nov 11, 2010 | 04:25 PM
labou1's Avatar
labou1
Default wheel bearing puller
Got one from harbor freight , used it on my front bearings and it works as good as the $$$$$$ ones
Old Nov 11, 2010 | 05:55 PM
SpiderPig's Avatar
SpiderPig
I went to our local Autozone store and they have tools that they loan out with a deposit. They had a blind bearing puller there that worked on a wheel with 25mm bearings. I made a press with 3/4 threaded rod and some washers and bolts for the install. Worked very well for only a couple of bucks. Might check out your local Auto Parts store.
Old Nov 11, 2010 | 06:35 PM
atrain68's Avatar
atrain68
Do you have the part number on that item? I might have to take a look at that. I ordered a cheap one online and return it. The construction was so bad I couldn't spin the bolt smoothly on the threaded rod. The thing actually stripped before I used it.
Old Nov 11, 2010 | 07:12 PM
DPete's Avatar
DPete
Thanks for the info, Auto zone here does not have, I ordered Georges kit, nuthin like the correct tool when it comes to wheels.
