Just installed the progressive DROP in springs lower the bike 1 inch in front,
after I got the spacing correct it really wasnt that bad of a job, remove front tire remove fender then remove the forks.
So got it back together IT RIDES LIKE A FRIGGING TANK
then after reading a little hmmmm I used the screamin eagle fork oil, so last night I drained the fluid used the TYPE E fluid, road to work this morning!!!! AHHHHHHHH
now rides like a caddy again !!!!
Installed heat demon grips also
road to work this morning 36 degrees I wore my lightest weight gloves
hands not cold at all!!!!
