oil pressure
Old Nov 11, 2010 | 06:13 PM
steveatkins's Avatar
steveatkins
Stage IV
Default oil pressure
I a 2005 electria glide and I am having oil pressure problems.
When I start it up first thing in the morning it is showing about 10 lbs of oil pressure. It use to show 32 lbs when cold. When I am riding down the road it will some times drop to some where around 15-20 lbs. And then it will jump back up between 32 and 40 psi. Can any one give me any suggestions on what is going on.
thanks
Old Nov 11, 2010 | 06:20 PM
dawg's Avatar
dawg
A few things to check...one is your cam tensioners if they are stock. They are prone to failure and could be disintegrating. Another thing is the relief bypass could be sticking. How many miles on the scoot?
Old Nov 11, 2010 | 06:26 PM
steveatkins
Stage IV
it only has 15000 miles on it.
Old Nov 11, 2010 | 06:32 PM
dawg's Avatar
dawg
General rule is to start checking the tensioners between 20-30k, that's not saying that they can't fail prior. However, your bypass might be sticking. You could always pop the cam cover and install a baisley spring. This can be done without having to pull the cam plate. While you're in there you could check the tensioners. The rear can be inspected without pulling the plate by using a dental mirror and a flashlight while prying it back. There are a few other things that can cause low oil pressure as well, but this is a start.
Old Nov 11, 2010 | 06:40 PM
steveatkins
Stage IV
thanks for your help.
Old Nov 11, 2010 | 06:42 PM
dawg's Avatar
dawg
You also want to make sure you're not sumping
Old Nov 12, 2010 | 08:49 AM
mainshaft's Avatar
mainshaft
Where do you live?
Old Nov 12, 2010 | 09:42 AM
bwana1's Avatar
bwana1
With an erratic gauge, lo pr at start up, I'd check the gauge first.
Bwana
Old Nov 12, 2010 | 10:02 AM
Sadist112's Avatar
Sadist112
Bwana
Yeah definitely or the sending unit could be gummed up. I'd definitely check those prior to spending an hour ripping that exhaust off!
Old Nov 12, 2010 | 11:13 AM
Neil's Avatar
Neil
Try putting a new sender unit on. I had oil pressure issues and the first time my tensioners were shot. After getting the tensioners fixed I again started having pressure reading issues I changed out the sender unit and things are back to normal. All suggestions are good. FYI, I had 32,000 on my 02 and the inner tensioner was completely shot.
Neil
RDMC
