I Shoulda Knowed Better
Old Nov 12, 2010 | 09:03 AM
oldbiker771's Avatar
oldbiker771
990rtracer has the part number, that is the one I have. Very high quality. It is essentially a fancy pipe cutter, but zuteuff, a pipe cutter won't work. It will not attach to the filter. A pipecutter has a wheel each side of the cutter, but an oil filter has only one side, so you need a single sided cutter with a top plate. Cyclonecutting, you kind of answered yourself. No-one really knows when these things need changing without inspecting them. The "go-bad" time varies so much among riders that you need to inspect regularly. Takes 10 minutes to check the filter thoroughly, about an hour to pull the exhaust and cam cover and check in there. This was not a one time use tool, but an every change on every vehicle tool.
ahmoose
Oil Archive (no new posts)
Dec 13, 2014 11:09 AM
J.R. White
Oct 8, 2012 08:04 AM
Gasturbine
Jun 4, 2012 02:43 PM
BasketCase87
Mar 22, 2012 01:47 PM
PPBART
Jun 18, 2011 04:37 PM
