You do plan on replacing the Main Drive Gear bearing I hope?
yes I do ,I will be ordering the 8967 and 35122-06,my 8967 bearing seemed to be fine but the outside needle bearing in the maindrive gear was bad along with my inner primary bearing and the inner primary race had walked on the shaft toward the tranny causing a leak ,what a b!tch to get that off ,it will be going back together with the baker high torque bearing,bike has 65000 kms or about 42000 miles .
You're replacing your input shaft assy? What happened?
Since you lost a needle bearing in your Main Drive Gear - I'd replace the whole assy (gear, bearings, seal).
It cost me a little over $60 from Zanotti and was a simple press in from there.
I was gonna suggest the Baker IPB. Sure makes it easier!
Never mind: Realized I was looking at the wrong part # on the gear assy!!!!
