Gear Drive
Old Nov 16, 2010 | 04:33 PM
Rickr01's Avatar
Rickr01
Default Gear Drive
How many with 2009 -2011 baggers with just simple Stage I upgrades have, or intend to change chain cam tensioners to gear drive?
Old Nov 16, 2010 | 05:41 PM
petemac's Avatar
petemac
IMO with the new hydraulic setup in the newer bikes it doesn't make much sense to go to gears. With the spring loaded tensioners in the earlier models people would go with gears to get away from the spring loaded tensioners.
Old Nov 16, 2010 | 06:36 PM
Biggzed's Avatar
Biggzed
I agree completely with Petemac. In addition, I doubt there are many '09-'11 twin cams running less than .003 runout on the crank. This is the common limit to run gear drive cams.
Zach
Old Nov 17, 2010 | 06:36 AM
Rickr01's Avatar
Rickr01
Zach
If this is the case, (runout) there must be thousands of scored oil pumps?
Old Nov 17, 2010 | 07:21 AM
Scorpion07's Avatar
Scorpion07
Why would you want to? The new system is bulletproof, and you don't need to mess with setup, worry about runout, or deal with the whine, and it'll last up to 70K miles!
Seems Harley finally got it right after 100 years.
Old Nov 17, 2010 | 09:45 AM
Rickr01's Avatar
Rickr01
That was the answer I was hoping to hear!
Old Nov 17, 2010 | 10:04 AM
mariner227's Avatar
mariner227
Zach
Yep. What bigzed said. Mine had only 500 miles on it when the build was done. Crank was out 003.
Old Nov 17, 2010 | 01:21 PM
Ribitt's Avatar
Ribitt
did it to my 07 ultra, 67,000 miles and no wine. least not that i hear. the new might be better but there is still plastic going in your motor.
Bingee
Jun 1, 2014 12:13 PM
slammed05fatty
Apr 1, 2014 02:06 PM
onthelaketx
Exhaust System Topics
31
Feb 28, 2013 05:25 PM
nsp261
Oil Archive (no new posts)
Oct 22, 2011 08:14 AM
Tanker2
Sep 22, 2010 05:53 PM
