wheel help!
Old Nov 18, 2010 | 08:03 PM
bigdrag's Avatar
bigdrag
Default wheel help!
I have an 08 street glide. Will I have to do any front fender changes to accommodate a 21 inch front wheel? Also what is the best size for the rear without having to make modifications?
Old Nov 19, 2010 | 07:52 PM
DuraGlide's Avatar
DuraGlide
Drill out the 2 rear mounting holes on the front fender to 3/8". Lift up on the back of the fender as you tighten up the bolts. Install the 21 and tape a 1/4" nut to the center of the tire. Spin the tire and if the nut clears the fender you are good to go. As for the rear, I'm running an 18 X 3.5 with a 150/70 18 tire with stock pulley and rotor and no mods.
Old Nov 20, 2010 | 01:29 AM
Jeff595's Avatar
Jeff595
I knew that worked when changing to an 18" wheel, but does it work with a 21" also? I was told I had to change the fender in order to fit a 21.
Old Nov 20, 2010 | 08:14 AM
DuraGlide's Avatar
DuraGlide
That is the stock fender drilled and lifted on my bike with a 120/70 21 Metzler. 18K miles and no issues.
Skid1
Jan 12, 2011 09:38 AM
Spartacus55
Wheels/Tires
11
Jan 4, 2010 05:34 PM
tbaehaney
Feb 8, 2008 01:10 PM
YtseJam
Dec 25, 2007 01:04 AM
Motown_HOG
Jun 3, 2007 03:26 PM
