Spark Plugs, is there a difference?
Old Nov 19, 2010 | 05:12 PM
CEJohnson21's Avatar
CEJohnson21
I've never noticed a difference in a properly tuned motorcycle or car.
Old Nov 19, 2010 | 07:16 PM
bagga's Avatar
bagga
i run the $1.29 on sale champions and i change them when they don't work anymore. if it ain't broke, don't fix it.
Old Nov 19, 2010 | 07:21 PM
Guntoter's Avatar
Guntoter
I use the platinum tipped plugs, the Harley ones, just so I don't have to change them near as often. I keep the old plugs in my tool kit as spares. There is very little difference in spark plugs outside of heat ranges. All those gimmicky tips do little. You can accomplish the same by snipping the ground back 1/2 the distance of the electrode. It does help a little on starting.
H-D plugs, at least the standard ones, are nothing but re-labeled Champions. I was surprised to find that out a number of years back.
Old Nov 19, 2010 | 07:29 PM
NoCoLoco's Avatar
NoCoLoco
Fancy spark plugs don't work any better, they just hold up better over time or with "extreme" use which most of us don't do. I change mine every spring so I just use OEM plugs.
Old Nov 19, 2010 | 07:34 PM
xxxflhrci's Avatar
xxxflhrci
I use platinums for their longer life. I usually run a set about 30k miles before changing them.
Old Nov 19, 2010 | 09:15 PM
BadBagger08's Avatar
BadBagger08
I run E3's along with Taylor made 10.5mm blue wires
Old Nov 19, 2010 | 09:23 PM
Retrop's Avatar
Retrop
Originally Posted by uscanuck
A plug might be a plug but I used some NGK's on my 2010 Ultra and using the TTS data recording was stunned by all the knock retard. Switched them out with the stock HD plugs and the spark retard disappeared.
Bike ran fine with the NGK's but the ECM was removing up to 8 degrees of timing. I don't think there was any real knock issue but the electronics obviously need to have exact resistance to work properly. If I were to use the NGK's again I'd likely turn the fast knock retard off.
And that is exactly why it would be in the best interests of all the late model touring bikes which have the spark retard built into the ECM should use only the OEM plug.
Old Nov 19, 2010 | 10:38 PM
Teardrop's Avatar
Teardrop
I use the stock plugs with no issues. I think the IR plugs are overkill and a waste of money.
Old Nov 19, 2010 | 11:25 PM
2KSport's Avatar
2KSport
+1 except black
Old Nov 20, 2010 | 12:55 AM
j1mmy's Avatar
j1mmy
HD plugs.. they are made by autolite, best plugs..what ever you do dont buy anything from accel for a hd..NGK work best in jap stuff..
