Spark Plugs, is there a difference?
Old Nov 20, 2010 | 09:06 AM
Jackie Paper's Avatar
Jackie Paper
Default Cross reference
Cross reference. Also not sure if ECM would measure resistance of a spark plug. How a Knock Sensor Work.
It detects the slightest noise in the engine and picks up on the "knock" of pre-ignition and sends the information to the ECM (Electronic Control Module). This ping is caused when the mixture of air and gas does not burn smoothly. This sensor is usually mounted on the cylinder and is connected to the ECM. When knocking or pinging is detected, the sensor sends a signal to the ECM, and this in turn retards the engine spark timing at two degree intervals until it has corrected the issue. The sensor's microphone is so sensitive it picks up the knocking when the human ear cannot detect it. It will hear the slightest ping even when the engine is at its top speed. A floating valve or bad lifter can trigger it.
Old Nov 20, 2010 | 02:57 PM
nvsteve's Avatar
nvsteve
Originally Posted by j1mmy
HD plugs.. they are made by autolite, best plugs..what ever you do dont buy anything from accel for a hd..NGK work best in jap stuff..
Nope, HD plugs are made by Champion.
I agree that Autolite plugs are very good.
Old Nov 20, 2010 | 03:00 PM
nvsteve's Avatar
nvsteve
Originally Posted by mkguitar
What NGK Iridium # are you Guys using? Thanks, Mike
DCPR7EIX
Don't expect any performance increase. They'll just last longer.
Old Nov 20, 2010 | 03:29 PM
Mav's Avatar
Mav
http://www.harley-performance.com/ha...park-plug.html
Old Aug 25, 2020 | 01:18 PM
Todd Lewis's Avatar
Todd Lewis
6th Gear
There is a difference in material and in some applications certain plugs work better than others. The job of your plugs, wires, coil is to eliminate misfires. The only reason to run iridium, unobtainium, etc is they last longer. Run a fine wire gold tip in the proper heat range and index them and your bike will perform better.
Old Aug 25, 2020 | 02:08 PM
scott_0's Avatar
scott_0
10yr old thread man
Old Aug 25, 2020 | 07:44 PM
ChetB's Avatar
ChetB
Champions
Old Aug 26, 2020 | 11:18 AM
Slingshot383's Avatar
Slingshot383
Now, if they made a 2 amp coil for HD's you would have all the spark energy that you could use and you couldn't develop enough cylinder pressure to blow out the spark. It could also seriously hurt you.
Old Aug 27, 2020 | 12:29 AM
ronbeejer's Avatar
ronbeejer
So glad you guys brought this 10 year old thread back to life... I missed it.
Old Aug 27, 2020 | 10:30 AM
Todd Lewis's Avatar
Todd Lewis
6th Gear
You may not have changed, but technology has in 10yrs,
