grinding noise from tranny
Old Nov 22, 2010 | 04:05 PM
bubba4u's Avatar
bubba4u
Default grinding noise from tranny
i just did a topend rebuild with little over 300 miles on it, now the tranny is making a grinding noise but is only in 1st and 2nd gear, sounds like its in the primary, anyone have an idea what it might be?
Old Nov 22, 2010 | 04:10 PM
TRVSDAD's Avatar
TRVSDAD
Could be a loose compensator nut, I had an intermittent grind a few months back, cost me 400.00 for a new stator, which was damaged by the loose compensator nut. Good Luck, hope it's a simple fix.
Old Nov 22, 2010 | 04:12 PM
Mike T's Avatar
Mike T
Sounds like the compensator nut has loosened up on you.
Old Nov 22, 2010 | 07:35 PM
bubba4u's Avatar
bubba4u
i don't know, i've had that happen before, don't sound like that,i can hear it when it's in neutral, stops when i put it in gear till i start rolling in 1st and 2nd gear then stops from 3rd and up and starts back up when i shift back down to 2nd and 1st till i stop rolling, sounds like gears grinding
Old Nov 22, 2010 | 07:51 PM
Mike T's Avatar
Mike T
You need to stop driving it before it causes some high-dollar damage in there.Look at everything really close in the primary.It shouldn't be hard to find.
Old Nov 22, 2010 | 07:54 PM
TORQUEY's Avatar
TORQUEY
Are you absolutely certain that you didn't accidentally "drop anything" into the lower end when rebuilding the top end?
Old Nov 22, 2010 | 08:16 PM
hedgehorn's Avatar
hedgehorn
I would adjust the front motor mount. Mine did that after the dealer was trying to find a vibration. Loosened the front mount and ran the motor then tightened it back up and the noise was gone
Crashrdking01
Mar 3, 2018 01:22 PM
scottie_unome2
Jun 26, 2017 03:04 PM
springers4ever
30
Oct 4, 2016 09:41 AM
gnogna82
Mar 12, 2014 08:56 AM
justin_faulhaber
Ironhead
May 20, 2008 10:13 PM
