Hells Foundry Dashlink another Ipod/iphone option
The HD unit is kinda cool - BUT you have to take eyes off the road too much when locating tracks on the ipod ( I test rode the CVO).
2. I use my ipod all the time and find it handy to have it in my line of sight when making adjustments. Having it in my fairing pouch is pretty good for that.
3. I tried a mount on the dash, and had glare problems.
I'll save the $400 for some awesome live to ride covers!
Mike
Not to mention the lack of integration with the handlebar controls.
If it cost $150, maybe. But at that price, I'd pass.
Their web site has a ton of information but I did notice that when you access it from your phone it is a whole different limited site.
www.cyclonecustom.com
-Rocky
It does work good though, rode for a few hours yesterday and enjoyed being able to choose what I wanted to listen to.
It is designed to allow use of the screen as integral to your ride. For example, you can use your navigation application (which is included on your iPhone). Using either of the methods noted above eliminates that option.
There are now more than 1,000,000 applications written for iPhone. Many of them can be used to a riders benefit. There are apps that provide virtual gauges like tach and speedo, etc. There are locate friend apps. There are Sirius/XM and Pandora apps. There are apps that stream your local radio stations from your home town while you're traveling. If your use requirements are only to play music that exists on your device, then the two "interface" options will likely meet your needs. If you want to integrate your very capable iPhone into your riding life, the screen is necessary.
DashLink is the only replacement console/dash with a docking station. It does not require removal of the outer fairing to work properly. It can be installed in under 10 minutes on most bikes. DashLink works on all HD radios, not just 2006 and up.
What do you do with your phone when it rains now? Seems like the same solution will work here.
Here's an install video for a Street Glide. It runs under 8 minutes.
http://www.hellsfoundry.com/instruct...l-dashlink.htm
Derik
