Roadtech zumo handlebar mount
Old Nov 27, 2010 | 12:50 PM
shy1's Avatar
shy1
Default Roadtech zumo handlebar mount
The Roadtech handlebar mount #92378-09 comes with instructions and connectors for hardwiring to the fuse box, etc. Has anyone done this, or is hardwiring to the accessory switch, battery, headlight, etc. better alternatives?
Old Nov 27, 2010 | 01:05 PM
SICKBAGGER's Avatar
SICKBAGGER
I have the Zumo 665 and mounted it on the faring. It has a inline fuse so what I did my amplifier is mounted on top of my radio. I took the hot right off the amp and the orange switched power right off there also. Works fine no issues and made for a clean and easy install.
Old Nov 27, 2010 | 01:34 PM
Jinks's Avatar
Jinks
Wired to the spare connectors behind the headlight it will turn on & off with the ignition. The exception being that when you turn the ignition off the Zumo will ask if you want to continue on battery. It gives you about 30 seconds to answer before it turns off automatically. If you want to use the GPS without the motor running you simply press "yes". My 550 will operate for several hours on it's internal battery.
Old Jan 26, 2011 | 02:35 PM
GreyfoxVt's Avatar
GreyfoxVt
3rd Gear
I too wired it to the spare connectors behind the headlight it turns on & off with the ignition as described above. Mine also has the exception that when you turn the ignition off the Zumo will ask if you want to continue on battery. It gives you about 30 seconds to answer before it turns off automatically. If you want to use the GPS without the motor running you simply press "yes". My 550 also operates for several hours on it's internal battery, and I plugged my speaker output to the Accessory in on the HD Radio. I even went as fax to connect to the external XM radio antenna, burried in the cowling. - GREAT SETUP!
Old Jan 26, 2011 | 07:10 PM
ucommbxny's Avatar
ucommbxny
on my 08 road glide i wired it to an empty slot in the fuse block using the pig tail they give you in the kit, it was a PITA, had to remove fuel tank to run wire in plastic tray under tank, take out battery to have room to do wiring at fuse block. most just run wire to the spade connectors on headlight wiring harness inside fairing
Old Jan 26, 2011 | 07:13 PM
tincup64's Avatar
tincup64
i think i wired mine to the cig lighter. works great and really looks like it fits with the bike.
tin
Old Jan 26, 2011 | 07:50 PM
strtarrow's Avatar
strtarrow
Tagging this for when I hook up my 660.
DavoRKC
Sep 8, 2016 03:32 PM
rstlnfan1
Apr 22, 2012 11:40 AM
t059736
Dec 20, 2010 03:01 PM
924shane
Apr 12, 2010 12:13 PM
Radical
Jul 21, 2007 08:10 PM
