Re-using muffler clamps or use new ones?
Old Nov 28, 2010 | 10:41 PM
Port Dawg's Avatar
Port Dawg
Default Re-using muffler clamps or use new ones?
I have a set of Screamin Eagle Street performance slip-ons on the way along with a new catless header pipe. I don't plan on putting the header pipe on until next spring but am thinking of throwing the mufflers on to see how they look and sound with the stock header with cat.
Am I able to re-use the muffler clamps that are on there or do you need to put new clamps on each time you swap mufflers? I do have a set, just wondering if I need to use them.
Old Nov 28, 2010 | 10:44 PM
SpiderPig's Avatar
SpiderPig
You should be able to reuse them without any problems.
Old Nov 28, 2010 | 10:59 PM
BlockHead96's Avatar
BlockHead96
They say replace hem, but I've re used mine once, then bought new ones, only like $8-9.00 a set.
Old Nov 28, 2010 | 11:00 PM
Navy UC Rider's Avatar
Navy UC Rider
Reusing them should be fine, but, with that being said, they are made for a one time use because when they are torqued, they take the shape of the pipe. I have reused mine with no problems, I have a neighbor that was getting some popping, we replaced them with new ones and he has been golden ever since.
Cale
Old Nov 28, 2010 | 11:08 PM
CEJohnson21's Avatar
CEJohnson21
I would use new clamps and keep the old clamps as an extra set.
Old Nov 28, 2010 | 11:17 PM
Garcou's Avatar
Garcou
I'd use a little high temp silicone when you Install those slip-ons.
Old Nov 28, 2010 | 11:24 PM
Oldman Harley's Avatar
Oldman Harley
I have used and reused the same set of clamps 3 times and have no exhaust leaks so the answer is yes you can reuse them.
Tim
Port Dawg's Avatar
Port Dawg
Ok thanks for the 411 guys
Why the high temp silicone?
Old Nov 29, 2010 | 05:28 AM
MX Mark's Avatar
MX Mark
I had trouble spreading them, to fit over new muffler, but was able to reuse them.
Old Nov 29, 2010 | 05:38 AM
Iceman24's Avatar
Iceman24
I'm **** - always buy new clamps & double-nut header flange bolts. Nothing worse than annoying exhaust leaks.
