Oil Circulation Problem with 2011 Limited
Old Nov 30, 2010 | 10:20 AM
DPete's Avatar
DPete
I feel for ya on that one, I think I'd push for a new engine, who knows what might have been damaged from starvation that might shorten the componet life.
Old Nov 30, 2010 | 10:40 AM
my67pnycar's Avatar
my67pnycar
Sorry bout your troubles man. Seems like they are trying to make it right with the loaner bike. I would push for a new engine if I was you.
Old Nov 30, 2010 | 11:44 AM
classic53's Avatar
classic53
I agree with what everybody else is saying. Push for a new engine. Who knows what is prematurely worn now inside.
Old Nov 30, 2010 | 01:39 PM
mtclassic's Avatar
mtclassic
these dang things can run forever on 1 quart of oil. My guess is his bike was sumping due to misaligned oil pump. Probably never have an issue.
Old Nov 30, 2010 | 01:56 PM
Easyglide's Avatar
Easyglide
Default Update on Limited Oil Circulation Problem
Just talked to the Service manager. Found a torn O Ring and it came that way from the factory. As a result, the compression was too low to pump the oil adequately through the engine. The mechanic does not believe any damage occurred to the engine, as their was still oil there - it just accumulated in the flywheel and lower engine, and there was still a quart or two left in the pan. I grilled him good on this, as I put 53 miles on the bike, hitting 3000 to 4000 rpms several times.
The mechanic is going to replace to O Ring, put all new fluids in the bike, check compression and test drive it to ensure everything is ok.
I am pretty sure the factory would not authorize a new engine, per my discussion with the Service manager. He even suggested I might want to call customer service if I felt strongly about it and understood my concern. But at this stage, they think the chance of any damage is remote.
If you can think of any questions I should raise before I take the bike out of the shop, I would welcome them. Again, I think the dealer is on the up and up. I just think the factory does not think any damage probably occurred and won't authorize a new engine.
Old Nov 30, 2010 | 02:39 PM
Ronp42's Avatar
Ronp42
Account Retired
If you can't get a new Engine,They should tear it down to see if there's any damage. They can easily tell if any damage has occured. Make sure you get everything documented and get a copy before you accept the bike. That's a terrible thing to happen with a new bike. You will be Leary of it now. Every little noise will make you nervous.
Old Nov 30, 2010 | 02:40 PM
Port Dawg's Avatar
Port Dawg
Good to hear...if they won't go the engine route...maybe an extended warranty for peace of mind?
Old Nov 30, 2010 | 03:42 PM
FDHOG's Avatar
FDHOG
Yeah, and if this was your brand new bike, I'm sure you would be the first one to be screaming for a new engine.
Dealer is trying to do the right thing. It's obviously a factory fault. I would also call the MOCO and talk to a rep.
Get a new motor.
Old Nov 30, 2010 | 04:42 PM
mtclassic's Avatar
mtclassic
Get a new motor.
Actually I would probably just ride the heck out of it being it under warranty. If it did not fail in 40,000 miles and 2 years I would figure it was good to go. Of course it is not my bike so easy for me to say I will say after being paid to abuse the heck out new harleys for the last 10 years that I do know for a fact that these motors are pretty friggun tough.
Old Nov 30, 2010 | 05:17 PM
robbie52's Avatar
robbie52
I would push for a free extended warranty just in case.
