Rough riding
Old Dec 2, 2010 | 06:56 PM
jpalm's Avatar
jpalm
Default Rough riding
I just got home from a running errands on the bike for several hours. After riding for a while and getting it warmed up, it is suddenly starting to feel like it's lugging under 2000 rpm's (like it's in too high of a gear, even in first). When I'm traveling at slow speeds it is vibrating pretty badly, and I noticed that it's idling rougher at stops. A couple of times when I took off from a stop I also noticed a "klunk, klunk" sound. It didn't sound like an internal engine noise, but more like a loose metal part hanging down and hitting the frame, but I thoroughly inspected it when I got home and didn't find anything loose. The only difference today is that it was in the 40's during my ride and I've never ridden it below probably 60. Is it possible the cooler weather is causing some of this behavior, or does it sound like something more serious?
Old Dec 2, 2010 | 07:01 PM
dawg's Avatar
dawg
First clarify your statement. Are you indeed riding it under 2000 RPM's or it is just feeling like it is under 2000 RPM's but the tach says otherwise. Secondly, the bike loves cooler weather as it is air cooled. They generally run much better. Does the noise sound like it is coming from the primary?
Old Dec 2, 2010 | 07:06 PM
jpalm's Avatar
jpalm
No, it's definitely when I'm riding at low speeds, like apparoaching a red light or moving at slow speeds that require me to ride under 2000 in 1st gear. The noise definitely doesn't sound internal, at least to me. It sounds kind of "tinny", like someone tapping the exhaust guard with a wrench or something. That's why I thought maybe the cool air on the hot exhaust guard might be causing a popping or something. The bikes runs great when I'm getting on it and riding above 2000 rpm's (basically everything other than the above described situation).
Old Dec 2, 2010 | 07:11 PM
dawg's Avatar
dawg
If you are under 2000 RPM's then you are lugging it and you would be hearing noises associated with lugging. Unless I'm not understanding you correctly. The later models (08 and up) have been notorious for clanky and noisy primaries as well.
Old Dec 2, 2010 | 07:25 PM
jpalm's Avatar
jpalm
I suppose you're right, I've just never noticed it like this before. As far as the noises go, I blew my cigarette lighter fuse today so my Hogtunes weren't working. Therefore, I had no tunes and had to listen to the engine. So I'm sure it's probably normal noises that have been covered by the radio before. I do feel the low rpm lugging is worse than usual so I'll keep an eye on it. Hopefully it's my imagination. Thank you for your input.
Old Dec 2, 2010 | 07:58 PM
mfuchs2004's Avatar
mfuchs2004
Maybe bad gas also. Are you in an area where they up the ethanol in the fall?
Also, are you a 'tank topper' who doesn't wait until nearly empty before filling? If so, get out of the habit because you're paying for at least a gallon of gas left in the pump and hose from the last guy in most cases. If the last guy got regular than that's what you just got even though you paid for good stuff.
A riding buddy taught me to wait for a guy getting premium and try to fill just after him and run as close to empty as I can to get the highest true percentage of premium as I can get.
Old Dec 2, 2010 | 08:05 PM
piasspj's Avatar
piasspj
Check your exhaust mounts and clamps.
Old Dec 2, 2010 | 08:36 PM
Wassup8687's Avatar
Wassup8687
I'd try adding some Seafoam. If there is any crap in the tank or a gummed up fuel system it'll clean it out.
When was the last time you changed the fluid in all 3 holes.
Old Dec 2, 2010 | 08:46 PM
jpalm's Avatar
jpalm
I just changed all three and switched to synthetic about 700 miles ago. It only has 1500 miles now.
flyboyron
Mar 24, 2014 06:59 AM
birdmandave
Jun 12, 2013 09:41 AM
berniemc
Aug 26, 2012 09:08 AM
KevenW
Aug 26, 2011 07:16 AM
doc25
Aug 2, 2010 09:29 PM
