Oil Pressure
Old Dec 4, 2010 | 09:24 AM
shore's Avatar
shore
Default Oil Pressure
What are your readings on the gauge cold and hot?
I just put a set of silver gauges on my 07 FLHT standard..40ish cold and 20 hot at idle....that's quite a swing in cold to warm pressure at idle. Up to 60 when riding.
is this normal?
Old Dec 4, 2010 | 09:55 AM
roadgliderick's Avatar
roadgliderick
yes it very normal mine does the same with a oil cool u might see a little more.
Old Dec 4, 2010 | 10:11 AM
coolerman69's Avatar
coolerman69
Sounds better than most i've seen. My 06 ultra with stock oil pump runs 40 45 cold and about 7 to 10 hot. Running down the road its about 30. This seems about the norm with my riding group.
Old Dec 4, 2010 | 10:29 AM
djl's Avatar
djl
This is about right for the later models with the upgraged oil pump. Earlier models (I have two) run 3-5 at hot idle and 30-32 at cruise. The air cooled vtwin does not require high oil pressures; as a matter of fact, high oil pressures can cause aeration. Once the air is in the system, lifters can bleed down and introduce some noise in the valve train.
Old Dec 4, 2010 | 10:34 AM
VTGlideRider's Avatar
VTGlideRider
I run right near 40 at first start-up. Once it warms up she idles around 20, and cruise is always between 30 and 34.
Old Dec 4, 2010 | 10:48 AM
The Old Man's Avatar
The Old Man
even at idle I get low pressure on my 08. 2-3 psi. 30is running. these are high volume oil pumps and you get plenty of oil no matter what the gauge says.
jpalladino820
EVO
Apr 20, 2017 06:43 PM
radudel
Apr 18, 2016 01:38 PM
Medicjaycook
Aug 13, 2011 01:18 PM
motormike69
Oil Archive (no new posts)
Jun 15, 2010 08:34 PM
Jsans
Nov 24, 2007 05:37 PM
