Clearing Cat in stock headpipe
Old Dec 4, 2010 | 12:43 PM
Mikebiker's Avatar
Mikebiker
Default Clearing Cat in stock headpipe
Hey guys, I have a '11 limited and was looking at a stage 1 upgrade. I have come to understand that the cat is in the headpipe on my bike and with the price of after-market headpipes I wondered if it was really that hard to clear the cat out of the stock headpipe.
Thanks ahead of time.
Old Dec 4, 2010 | 01:08 PM
davewear's Avatar
davewear
it has been done, there are threads on it. try a search with 'cat', or 'cat removal' something will turn up.
Old Dec 4, 2010 | 01:10 PM
Bigiron's Avatar
Bigiron
There are several threads on cat removal. Try the search feature. I bought an 09 headpipe from a forum member to put on my 2010 Limited, but am considering V&H True Duals, as I think they allow a better sound.
Old Dec 4, 2010 | 01:11 PM
03dragonRK's Avatar
03dragonRK
I cut my pipe in half where the cat is (large collector aera) and used a 1/2" drill bit to drill around the cat as close to the pipe as possible and then use an old chisel to cut out the rest. I then used a die grinder to clean up the pipe. May not be required but I scratched a line down the pipe before I cut it so I would have something to line up the halves since I was sending the pipe out for welding.
Cost me $20 for the welding and then I had the pipe ceramic coated for $115. My total cost is $135.
Beware removing the cat material is a dirty job and you may want to wear a filter mask to protect your lungs.
mdj6j
Oct 30, 2018 10:45 AM
leadman
Oct 7, 2014 10:52 PM
DannyZ71
Southwest
Nov 13, 2011 11:42 AM
iwillfixthem4u
Apr 11, 2011 12:53 PM
hydrolock43
Jun 11, 2010 09:48 AM
