Synthetic Oil
Old Dec 5, 2010 | 12:43 AM
mkguitar's Avatar
mkguitar
---and I use the factory recommended products.
I have 4 Harleys in the garage right now,Twin Cams, Evos and Panheads.
I have owned many brands of motorcycle over the years.
My experience tells me to use products purpose made for these bikes- oil is a crucial part of the cooling system on these bikes.
and change at or before service intervals- ALWAYS store a bike with fresh clean oil.
my newest bike is a 2009, I can't believe how nice and clean the oil is coming out at changes, with I still do at 3000 miles.
oil is cheap, filters too
MK
Old Dec 5, 2010 | 01:59 AM
Tek74's Avatar
Tek74
+1 on using any reputable high end synthetic oil. I use Amsoil for all my bikes/cars.
Old Dec 5, 2010 | 07:48 AM
hd4evr2008's Avatar
hd4evr2008
Mobil One V-Twin in the engine, Mobil One 75-90 gear oil in the tranny, HD Formula + in the primary.
Old Dec 5, 2010 | 07:50 AM
mariner227's Avatar
mariner227
MK
I agree! My main concern is reports of varnish build up on valve stems, causing the valve to stick. This is definitely oil related and happening to a few low mileage bikes. Usually the rear cylinder exhaust valve. I use Redline in my motor.
Old Dec 5, 2010 | 08:05 AM
Jerry1834's Avatar
Jerry1834
Redline in everything but the others are just as good.....just make sure you change every 3-5K and you will be fine.
Old Dec 5, 2010 | 08:18 AM
93+octane's Avatar
93+octane
SInce I first got interested in deep frying turkeys about 10 years ago I learned that peanut oil has a much higher burn rate so that is what I use.
Amsoil in the crank, Lucas in the primary and tranny works good for me.
flatfifth2003's Avatar
flatfifth2003
MK
I agree, my question to the OP is what is so wrong with Harley oil?
Old Dec 5, 2010 | 08:22 AM
printer2's Avatar
printer2
5th Gear
Smile Oil
I think all of the quality products are good. The main thing is to change the filler and the oil.
Chicago
Old Dec 5, 2010 | 08:35 AM
jimsreddyna's Avatar
jimsreddyna
For the engine, it's a toss up between Mobil1 and Amsoil. For the primary, you will find that every oil you put in there will give a little different feel to the clutch. Find one you that you like the way the clutch works.
For the trany, I have been running Spectro 6 Speed and found it quiets down the 5th gear wine and take away almost all of the 1st gear noise on decel. When I had my 25K service done, the shop called to tell me they were out of the Spectro and aked if I would try Redline Shockproof. I let them put in the Redline and although it is quieter than the SYN III, it is not as quiet as the Spectro.
Old Dec 5, 2010 | 08:36 AM
Navy UC Rider's Avatar
Navy UC Rider
I use Mobile V-twin in Engine and Primary and Mobile 75-90 gear oil in the transmission. Thinking of switching to the heavier Mobile in the transmission at the next interval.
Cale
