Computer connection
Old Dec 5, 2010 | 04:12 PM
Hrlyrider's Avatar
Hrlyrider
Default Computer connection
Has anyone had any problems where the wires connect to the computer? I took my seat off put it back on and the bike would not fire. When I removed the seat it started, when I would push down on the computer connection it would cut out. I have a 2008 whith the Fuel pak, when I disconect the fuel pak it runs fine but it still doesn't feel like the connection is locking on straight. I just ordered a PCV hopefully it will connect to that with no problems.
Old Dec 5, 2010 | 08:43 PM
Hrlyrider's Avatar
Hrlyrider
No one else has had this problem?
Old Dec 5, 2010 | 08:58 PM
Lass7711's Avatar
Lass7711
I had a little problem once with the ECM ground pin not making good contact. It's the flat pin in the plug. I had to twist it ever so slightly to make it fit a little tighter in the hole.
I've never had a problem with the plug not connecting straight. You might want to take the plug apart to make sure all the pins are straight.
Daddywags
Electrical/Lighting/Alarm
Sep 30, 2018 09:09 AM
Daddywags
Sep 29, 2018 11:39 AM
dino733
Jun 14, 2010 10:24 PM
NJSUPERGLIDE
Apr 25, 2006 12:43 AM
