The problem I have is two fold one costs money and I'm still working on the second. A jack is an absolute, I still need to do that. The second is that my bike does not get dirty enough to require a soap and water wash very often. Normal 50-100 mile rides get them dirty. An easy sort of "dry" clean method has not been found. They look nice, but it is difficult to keep them as clean as I would like without soaping it up and hosing it down.
+1 on the Westley's and a 3M Scotchbrite pad. Just rinse off the tires and rims with the hose when you're done and no harm will come to your rims. Been using this crap for years.
Who?Me? You can't see how dirty your tires are while you're riding. Just ride more.....What kind of roads are you riding on if they get dirty in 50-100 miles?
I clean mine occasionally (3 times in 1K miles), and no matter how crappy they look, they still come clean. Gotta have a lift, it takes 10 min. and you don't have to soap up the whole bike.
Mine only really get dirty when I ride in rainstorms, and the brake dust gets deposited on them.
I'd much rather use the Wesley's over Simple Green. Simple green will definitely corrode aluminum, and will strip certain coatings off as well. It works like a champ, but it's really nasty stuff.
Wesley's works okay and I'm not as worried about damaging my rims, although I am quick to hose them off.
I've only cleaned my whitewalls twice in 2500 miles, I don't have a lift though. Santa should be delivering one in less than a month.
Plus one on the bike jack. Most cleaners do a good job but its a pia to keep moving the bike to clean your tires. Had the wide whitewalls on my Road King and looked sweet.
When I had my 06 Roadking Classic, I used Comet w/ bleach, Scrub Brush, SOS Pad, a Bike Jack, lots of elbow grease and little time. Always paid off to go the extra mile. You want to set off a classic from the others just clean those white walls up real good. Beautiful bikes.
Bear in mind using steel wool, SOS, scotch brite etc when cleaning you white walls. These products are "abrasive". The reason you see results with them is because not unlike paint you are removing material from the surface. JMHO.
