LED Head Light Comparision JW & TL
Steve K.
Sorry, no wiring diagram to share as my dealer did it for me but I bet a search here would turn something up.
i'd also like to find out more about these new l.e.d. headlights. i'm currently using the hella E code headlight with a great osram/sylvania bulb. it's a huge improvement over the stock harley headlight, but i really like the idea of the led light if it lights up the road better. the link for me didn't work either, but i'll check back tomorrow and perhaps it will. thanks for the information.
I have the hella in my dyna 7" light, no comparrison to the LED, better than stock though.
I agree with masterblaster - I had the Hella E code with Osram 65/70 halogen. Better than stock, but ran hot. Either of the LED headlights are by far better.
I plan on adding the HD LED auxilary lamps and wiring them to stay on all the time. Someone in this thread mentioned some states do not allow this. Any information on which states or where one might find that information would be appreciated. Thanks again.
I have my passing lamps wired up so they're on all the time if the toggle switch is on, and off if the switch is off. With this set up you'd be fine no matter what state you rode in.
Actually it's a federal dot lighting ordinance. Technically, any auxiliary forward lighting (whether they're called driving lamps or fog lamps or passing lamps is irrelavent) is required to turn off when the high beams turn on.
I figure as long as the lights are aimed properly, most (but not all) LEOs will not ticket for it on a motorcycle - they understand the 'see & be seen' concept.
Follow this link for a PDF with a couple of alternatives to accomplish the goal, including wiring diagrams - www.lrsanitary.com/0/PassingLamps.pdf
Hope this helps...
I just wanted to post some links for additional information/photos of the Truck-Lite LED Headlamp mentioned within this article, as it pertains to the conversation. Truck-Lite also has a technical support line that can help with installation or technical questions @ 888/562-5012.
Product Information:
http://www.truck-lite.com/webapp/wcs...4057&langId=-1
http://www.truck-lite.com/webapp/wcs...0001&langId=-1
Product and Installation Photos:
http://www.flickr.com/photos/truckli...7625408456422/
http://www.flickr.com/photos/truckli...7624969893874/
Let me know if we can help.
Thanks,
Jerry Lee
Truck-Lite Co., LLC
Thanks and ride safe,
Bob.
Hope this helps...
Replace that 65/70 with the 80/100 and your see a big difference. Wire in a NAPA bakelite headlight plug socket and don't worry about the heat.
Anyone knows if the HD trim ring works with the JW/HD LED headlight?
I have the visor trim ring, and it fit without much hassle (about the same BS as usual with it).
