Concerns about the electrical system while doing mods
I have my bike torn apart for the winter doing mods. My tank is off, the whole front end is off, pipes, speed/tach, directionals, and a few other things. I want to do some 12v testing of the radio, amp, different bulbs, dash guages, alarm system, load equalizer/led lights, run some wiring, etc... When I started my mods I pulled the main fuse and battery and then went to town.
My question is I want to put some power back to the system to work on my electrical mods. I don't want the bike to go into a starting mode like the fuel system kicking in etc... I know I could just go to the accessory setting but is that it? Am I missing anything that might be on thats not necessary? With my speed/tach off, partial directionals, etc.. are there any issues that could throw codes that I would have to have the dealer take care of or worse? Should I pull some fuses like the fuel pump, ecm, starter, etc..?
FYI, I can't hook everything back up to be safe because a lot of parts are out being painted/powder coated and at the shop. Before all this computer stuff I use to do all this without a thought. LOL
Any codes thrown, you can clear yourself. If it makes you feel better, pull the fuel pump fuse if you will be turning on and off your ignition. I wouldn't worry about anything.
