Too cold to ride.....time to mod
Old Dec 12, 2010 | 07:33 PM
tidbit1's Avatar
tidbit1
Smile
Originally Posted by modes
Well weather and temps are one thing....but this time of year the more important thing I watch is the public wokrs department....this morning it was 43 and raining. The city truck drove buy laying down salt. I was confused why, but none the less the bike and summer truck don't come out of the garage until 1 heavy or 2 rainstorms to clear away any salt residue.
Got some more work done on my project and took a bunch of pictures to show my work.
Here is the beginning of the right side. Lower support removed and the frame unchanged.
I taped off the fender to reduce any scratching
Frame cut as per the directions
I cut the lower supprt as directed...used to be two holes at the top. Here they are cut and in place to be bolted up.
Seeing I got a deal on these from an attic sale, the metal brackets that would have come in the kit were missing...now worries as I would of had to mod them and I rather get the deal in $. So here are the brackets that I made
When it was all together the ride side was pushing the fender towards the wheel reducing the minimal clearance between the fender and tire so I "thinned" the bracket I made for the ride side to retifiy this problem. After the "thinning" the tire to fender clearance was pretty close to even on both sides.
Here is my poorman mill to thin up the bracket. clamp, drill, move, clamp, drill, move, clamp, drill, move, etc. Slow and tedious but gets the job done well.
And the results of the milling
Here is the bracket in place (before the right one was milled)
I had to cut the rear docking kit bracket to match the cut I made in the lower supports. I did not want to rely on the 1/4" rear saddle bag bracket bolt to keep the docking hardware bracket in place from rotating, so I made beefier connector bars running from the rear to front docking kits. Here all that is in place
Here is the sissy bar in place to be sure all lines up properly and will work
Time for the filler panels. First I had the cut the lower flap that goes from the top of the shock to the rear saddlebag cover latch access to allow for the attachments to get to the docking stations. Then I placed the panels roughly in place and had to cut recesses for the bars I made that run from front to rear docking points. Here is the left panel in place
And the left filler with bag in place, scribed and sanded to fit
And a rear shot of both in place
A couple of minor things to touch up then pull it all apart for paint and powdercoat. Next up is the new license plate relocation bracket for under the left bag.
Adam
Man that was a lot of work but is gonna be worth it. In seeing the lights on your bags i want to tell you i have just added lights to mine. I added tear drop in red that look like the ones on a 39 Ford..
Old Dec 26, 2011 | 11:01 PM
jodybbad's Avatar
jodybbad
Stage III
Thanks i was wondering about that just didnt want to spend 200 bucks to learn that i couldnt modify it to use detachable backrest. Now where did you get them for 110?
Old Dec 26, 2011 | 11:42 PM
dickey's Avatar
dickey
That's a little too radical for me. I would never do a mod that required any frame cutting--in case I wanted to go back to stock. Good luck with your mod.
Old Dec 27, 2011 | 12:02 AM
utlonghorns416's Avatar
utlonghorns416
Nice job..
Old Dec 27, 2011 | 06:00 AM
fabrik8r's Avatar
fabrik8r
The project is nice, but I wanna know what that drill press is, it looks like it might be an old piece of American machinery.
matt76cmich
Audio Systems
34
Oct 31, 2017 09:45 PM
sober1
Jun 5, 2014 05:34 PM
Bulletcatcher
Jan 28, 2010 05:57 AM
bdaug50
Mar 21, 2009 09:42 AM
drrandall1
Apr 9, 2007 09:29 AM
