help stranded
Old Dec 12, 2010 | 09:41 AM
TickTock's Avatar
TickTock
Default help stranded
Buddies 2010 EGC wont start and the security lights flash. Cannot get past that. Tried manual security override will not allow entry. Need some ideas as we are stuck. Basically all buttons work but start switch.
Old Dec 12, 2010 | 09:45 AM
TickTock's Avatar
TickTock
Nm looks like bad security fob battery
Old Dec 12, 2010 | 09:47 AM
lionsm13's Avatar
lionsm13
How about pulling off the right side cover and pulling the main fuse and leaving it out for a few minutes and then putting in back in? Would that do anything?
Old Dec 12, 2010 | 10:06 AM
PistonPuller's Avatar
PistonPuller
Bet the battery in the FOB is dead and somehow the manual code is wrong. Maybe he thinks he knows the code but could be wrong? Or maybe it was set wrong? Get a new FOB battery
Old Dec 12, 2010 | 10:10 AM
rg_dave's Avatar
rg_dave
FOB battery. He doesn't remember his code. Next time he needs to make it something he can remember. This is a lesson for me because I have no idea what mine is!
Old Dec 12, 2010 | 10:12 AM
dansflhti's Avatar
dansflhti
I had a similar problem back in Aug.My 09 was still under warranty and had to get trucked to the dealer.It ended up being the battery in the bike.It was less than a yr old.
Old Dec 12, 2010 | 11:07 AM
TickTock's Avatar
TickTock
Made it home so I can type a little more now. The issue really was that the start switch wouldn't work at all and the security lights would just flash. We could not get the bike into the mode where you can enter the manual security mode Not sure why - maybe we didn't push the flasher in fast enough or something. It was just odd... Anyway, desperate times call for desperate measure so after pulling the maxi fuse and the starter fuse we decided to try the old key fob battery switchover trick. Bike fired right up!
Note to self - keep a spare battery in saddlebag...
Old Dec 12, 2010 | 11:33 AM
Mr Cujo's Avatar
Mr Cujo
Check the starter bolts. Make sure they are tight. It seems to have been a recurring problem in '07 - and was on mine, demonstrating the exact same symptoms - maybe on your '10 there is a similar problem.
Old Dec 12, 2010 | 11:37 AM
Faast Ed's Avatar
Faast Ed
Glad it was the easy solution!
When you tried for the manual entry, did you have the key in the on mode? or the Accesory mode?
Old Dec 12, 2010 | 12:06 PM
macride's Avatar
macride
agree on the fob battery.... don't ask how I know.
