3M Tape Application
Old Dec 13, 2010 | 05:03 PM
sanlyn's Avatar
sanlyn
Default 3M Tape Application
I have chrome inserts for my saddlebags to replace the reflectors. I've removed the reflectors (thanks all for the advice). The area is clean, now I need to install the chrome inserts. The temperature is somewhere in the mid fifties here. Will the tape adhere okay in this temperature? Should I heat the surface before applying? Any suggestions?
Old Dec 13, 2010 | 05:05 PM
tj316's Avatar
tj316
it's the temperature of what you are installing it on that matters, feel the surface and if its real cold by touch warm it up a little, but don't heat it up
Old Dec 13, 2010 | 05:20 PM
Fatboy Brian's Avatar
Fatboy Brian
Don't forget to clean the surface with alcohol or something else before applying the tape.
Old Dec 13, 2010 | 05:34 PM
sanlyn's Avatar
sanlyn
I removed the old reflectors, and cleaned the surface thoroughly with goo be gone, then with isopropyl alcohol.
Old Dec 14, 2010 | 04:41 AM
emwolb's Avatar
emwolb
remove the saddlebags and bring them inside for the install. it'll ensure better adhesion being where it's warm. also like the other guy mentioned, you were right to use alcohol to clean any residue so they'll stick well. the bags are easy to remove so bring them inside where it's warm.
Old Dec 15, 2010 | 10:23 AM
sanlyn's Avatar
sanlyn
Doi! pretty stupid of me not to think of that. I know it's been a bad month, but I guess I'm not thinking straight.
Anyway, they're inside warming up now (the cats are real interested in them). Thanks for suggesting the obvious, I guess I needed that.
samk9lover
Aug 25, 2018 01:38 AM
daulton73
Welcome Area Only
16
Aug 29, 2010 07:44 AM
RobPic
Apr 18, 2009 10:12 PM
SSZ7D
Sep 4, 2007 06:25 PM
Aces N Eights
Jan 26, 2007 11:22 PM
