Losing the tourpak!
Old Dec 16, 2010 | 09:03 AM
Scorpion07's Avatar
Scorpion07
Sure are a lot of BS assumptions going on here!
The guy just wants to remove his TP without the crappy looking "quick detach" option.
Harleypingman is always spot on. So you might have to have someone fab a bracket.
Old Dec 16, 2010 | 12:06 PM
Rat1's Avatar
Rat1
The bracket for the quick detach backrest is not all that bad and is not even noticable with the backrest installed.
I did alot of shopping around looking for a ridged mounted backrest also. I came up with zilch and had to buy the kit. My tour pack is sitting on a shelf in my garage incase I need it for a longer trip. Takes me less then 30 min to put it back on.
Old Dec 16, 2010 | 12:14 PM
Iceman24's Avatar
Iceman24
I added black quick detach to vivid black bike & you can hardly see it...also, I believe HD makes covers for the detach HW to make the rear look cleaner. Might be worth a look...
Old Dec 16, 2010 | 06:07 PM
JBHDUltraClassic's Avatar
JBHDUltraClassic
Originally Posted by Peppa1
I have an Ultra with the detachable tour pack and only use the tour pack for packing for long trips. I liked the other features that came stock on the Ultra, vented lowers, cruise.
Thank You!
Old Dec 16, 2010 | 06:09 PM
JBHDUltraClassic
Exactly B.S. assumptions.
Old Dec 16, 2010 | 06:12 PM
JBHDUltraClassic
Originally Posted by Harleypingman
It won't matter what model you shop for since HD hasn't offered a rigid/permanent mount passenger backrest for the '09 and newer Touring models that have the new frame/rear fender. HD did offer a rigid/permanent mount backrest for the older frame/fender but discontinued it prior to 2004, opting for the detachable offerings.
Carl
Thanks
Old Dec 16, 2010 | 06:41 PM
Mike's Avatar
Mike
Funny when someone with a Street Glide starts adding a tourpak and lowers, and he gets told he should have bought an Ultra and stripped it down. Here's a guy who wanted to do that and he gets told he should have bought a Street Glide. sheesh.
Old Dec 16, 2010 | 07:20 PM
IndyClassic's Avatar
IndyClassic
I love the look of UC's without the Tour Pak. If I ever buy that model (and it crosses my mind time-to-time) I would get the quick disconnect since I ride solo 95% of the time.
I do not mind the look of the posts on the RKC however and have all 4 so I can use backrest or the RK Tour Pak. Maybe it won't bug you as much as you think once installed.
That or have something fabbed up as suggested. Didn't a regular on here do a write-up last year on doing his own "quick disconnect" wiring, etc with full pics? I wonder if he devised a way to avoid using the posts/mounts as well? Just a thought.......
Old Dec 16, 2010 | 07:29 PM
IndyClassic
Sorry JBDH.....it was by UltraKla$$ic I was thinking of and covers wiring extremely well but appears he did use the quick disconnect posts.
https://www.hdforums.com/forum/touri...etachable.html
sumncguy
Touring Parts
15
Oct 17, 2016 06:35 PM
dontdropit
Touring Parts
30
Jul 8, 2013 09:39 PM
Sincecrazy
Touring Parts
Feb 14, 2010 11:58 AM
ken b
Aug 21, 2009 12:49 AM
shearpinn
Screamin Eagle CVO Models
Nov 7, 2006 06:54 PM
