visibility
Old Dec 19, 2010 | 11:48 PM
emwolb's Avatar
emwolb
i'm using the harley taillight module that makes the turn signals also glow as running lights and still work as turn signals. the kit includes the red lenses. the next thing i did to improve visibility was installing the B.A.L. and it stands for bright *** light. it sure is bright indeed. i keep it set on the brightest tail light setting and the brightest flashing brake light. all this was done to hopefully keep some 22 year old kid from rear ending me while they're texting. the BAL is so bright that you can't ignore it at all.
Old Dec 20, 2010 | 01:10 PM
badjustbad's Avatar
badjustbad
Originally Posted by hardwareguy
I hadn't thought of the front fender light. Does changing this out to LED make much of a difference?
The change in brightness is minimal at best. My opinion, it's only for looks and with the LEDs behind the grey lens it was a step backwards. The LEDs are mounted on a white circuit board which shows through the grey lens. I used a marker to black out the circuit board - looks better now.
Originally Posted by gambler
I added the run/brake/turn option for the tail lights AND the tour pak. I also have the "Back Off" flasher for the tail lights. I haven't felt the need to go to LEDs, but every little bit helps.
I added the run/brake/turn module and bullet lights to my RKC (And now the Ultra.). With the red bullet lens the signal lights weren't very obvious, according to the guys I ride with. I installed LED lights in the signals which greatly improved the visibility of the lights but then the brake light wasn't as obvious. I installed the LED brake light to complete the package (Both bikes.). Now the guys I ride with want me to be the last rider in the group - my lights are too bright and it hurts their eyes to follow, especially when it gets darker out. Perfect!
whiskeyfire
Dec 3, 2018 05:18 PM
captainjack
Jan 3, 2011 03:10 PM
rmack888
Electrical/Lighting/Alarm
Oct 15, 2010 12:59 PM
jimclaypool
Jan 4, 2009 10:35 PM
questor
May 5, 2008 01:50 PM
