What to do with a 88TC?
Old Dec 19, 2010 | 10:05 PM
TO34's Avatar
TO34
Default What to do with a 88TC?
Well thinking its winter & I have a lil coin ... So given its stock year 2000 & I dont want to go crazy because its a daily ride for me. What are some ideas to bring it to life? but a lil more zip in it so to speak without making it highly unreliable ?
Old Dec 19, 2010 | 10:08 PM
DTTJGlide's Avatar
DTTJGlide
First how many miles does it have on it, what year is it & how much do you want to spend?
Old Dec 19, 2010 | 10:10 PM
MAJOR's Avatar
MAJOR
Check out this ebay item #290512874977 if you have a silver engine this seem like a good deal for the big bore kit and cams.
Old Dec 19, 2010 | 10:16 PM
07RoadHawg's Avatar
07RoadHawg
Without knowing your budget limit, I'd suggest a top end kit (assuming your crank/bottom end is in good shape) from Hillside, HQ, T-Man, etc. They can do a 98" with headwork and a set of cams to achieve your goal (more zip). These builds have shown to be very reliable due to high quality components and top notch machine work from these reputable shops.
Old Dec 19, 2010 | 10:18 PM
dawg's Avatar
dawg
Originally Posted by TO34
its stock year 2000 ...... its a daily ride for me.
If it's totally stock and you haven't checked/changed the suspect cam bearings, I'd certainly start in the cam chest with any upgrades.
Old Dec 19, 2010 | 10:20 PM
strtarrow's Avatar
strtarrow
I have had my 01 RK up to 105 MPH and that was just to see what it would do. How fast do you need to go? Too much to spend my money on but if you are adamant there are bigger engines you could plant on it besides engine mods. Personally I am perfectly content with my 88 ci.
Old Dec 19, 2010 | 10:26 PM
misfitJason's Avatar
misfitJason
cam gears from s&s and stage 1 kit
Old Dec 19, 2010 | 10:27 PM
slyder's Avatar
slyder
Id say start with the cams and chain tensioners. Especially if you have around 30,000 miles on it. Its usually the inner tensioner that gives you problems but they both wear.
cams, headwork, exhaust and a good breather should make you smile.
littled62's Avatar
littled62
next weekend I'm changing my cams, have a 05 ultra with 36k the dealer told me one of my cam tensioners was pertty worn and it would cost $600 just to replace them I decided to put a little more with it and upgrade to the hydralic tensioners and the woods cams from fule moto, do it my self and save $500 in labor cost. Wife has to work xmas weekend, kids and grandkids all live over 400 miles away so have 4 days to take my time and do it..
Old Dec 20, 2010 | 06:09 AM
grbrown's Avatar
grbrown
The cheapest thing you can do is change the 25T compensator for a 21T with the SE kit. Comes with a shorter chain and increases rear wheel torque by 19%. That's nineteen percent! Top speed is reduced from a theoretical 140mph or so to a more sensible 120-ish and goes like a rocket. Did mine several years ago. Mild Stage 1 stuff will wake it even more.
