Throttle Question
Old Dec 20, 2010 | 10:11 AM
Bugspit's Avatar
Bugspit
Default Throttle Question
I replaced the grips last night and everything went smooth. I checked the throttle and it snaps back into idle with no problem. But I also noticed that I can turn it a little the opposite way. Is this normal? I may have never noticed it did this before and was just double checking.
Thanks!
Old Dec 20, 2010 | 10:16 AM
mcneal's Avatar
mcneal
With the newer Harleys you can cut out the rear cylinder when idling in hot weather by turning the throttle past idle & holding it there for a few seconds...this is designed to help keep heat off the driver.
Old Dec 20, 2010 | 10:25 AM
Navy UC Rider's Avatar
Navy UC Rider
Wow, did not know that bit of info. I thought it was an automatic thing, if it was engaged through the ECM. I will have to give it a try tomorrow.
I use the roll forward to disengage the cruise control, around here, brake checks aren't really a smart thing.
So, short answer is, yes, it does roll a little forward.
Cale
Old Dec 20, 2010 | 10:35 AM
Bugspit's Avatar
Bugspit
Thanks guys. Its funny I never noticed it before and when I was testing the grip I said whoa is this normal.
Old Dec 20, 2010 | 10:43 AM
taximan62's Avatar
taximan62
All explained in the owner's manual under EITM (Engine Idle Temperature Management)
Old Dec 20, 2010 | 10:52 AM
shore's Avatar
shore
You say newer Harley's but what model years does this roll forward thing work for?
Old Dec 20, 2010 | 11:22 AM
badjustbad's Avatar
badjustbad
You can also roll the throttle forward to disengage the cruise control if ya got it.
Old Jan 2, 2011 | 08:11 PM
Nute's Avatar
Nute
It is sometimes referred to as "parade mode". It came out with TBW. I know it's on the '09 and later and I believe it to be on the '08 as well. When the bike comes from the dealer the default is that it doesn't activate. Look in your manual to see how to activate it. Once it is activated it very easy to turn it on and off. It really does reduce the heat when sitting at idle. There is some kind of safety that you can't activate it unless the temp of the bike and the ambient temp have reached a certain temp.
Old Jan 3, 2011 | 07:34 AM
1flhtk4me's Avatar
1flhtk4me
My '06 Road Glide throttle would roll forward a little if forced,did not come to a solid stop.
Did not know about the newer TBW parade mode activation.I guess I should RTFM!
ppilotmike
2018+ Softail Models
Sep 26, 2019 12:18 PM
harley0101
Dec 18, 2014 09:53 PM
osudvm
Jan 20, 2013 05:54 PM
sajackson
Oct 11, 2011 09:21 PM
Operator
Jun 3, 2008 11:56 AM
