Throttle question
Old Jun 3, 2008 | 09:57 AM
Operator's Avatar
Operator
Default Throttle question
I started up my 08 Ultra last night and noticed the rpm's were idling at 2000. I assumed I had the same issue that other people had and had shut the bike off when it was idling high. I turned the throttle forward thinking it might be stuck, and the rpms shot down to 1000 and stayed there. I tried to find out what this did besides turning off the cruise but couldnt. Any idea why it would do this. I'm sure its a simple answer but I couldnt find anything.
Old Jun 3, 2008 | 10:07 AM
confused's Avatar
confused
Default RE: Throttle question
Do a search for high idle and I am sure you will get your answer
You will need to reset your ???
Something like on/off five times, yada yada yada
Old Jun 3, 2008 | 10:09 AM
Operator's Avatar
Operator
Ya, I know I had to do that since I probably shut it off at a high idle. But instead of doing that I turned the throttle forward while it was running and it slowed way down. Started it up again and it was fine. I'm trying to find out what the purpose of turning the throttle forward is.
Old Jun 3, 2008 | 11:56 AM
caymen8's Avatar
caymen8
I had the same issue on my RG, just for a day. Rolling the throttle forward brought the RPM's back down (but only while it was rolled forward). After a restart it idled normal again. That was two months ago and it hasn't happened again.
ezryder62881
Nov 2, 2016 08:09 PM
Bugspit
Jan 3, 2011 07:34 AM
thehueg
Aug 15, 2009 04:20 PM
scampman_73
Jun 20, 2009 05:01 PM
SenecaBlues
Mar 17, 2008 03:40 PM
