Changing Wheels
Old Dec 21, 2010 | 08:19 AM
FDHOG's Avatar
FDHOG
Default Changing Wheels
In the process of changing the wheels and tires on my 11 RKC. Do you really have to remove the front (ABS Side) brake caliper to get the wheel off?
Reading the Service Manual makes it look harder than it should be. Rear wheel also.
I removed my Fatboy wheels a few times and it was pretty straight forward.
Should I get the new wheels balanced with the rotors and sprocket on them, or does it really matter?
Old Dec 21, 2010 | 08:50 AM
Roadie09's Avatar
Roadie09
While it may be possible to remove the wheel without removing the caliper, it will take a lot longer. It only takes a couple of minutes to get the caliper off and couple of minutes to put it back on. I can only imagine the amount of time and frustration trying to get the wheel back into place plus slip the sensor in while the caliper is still mounted.
Removing the ABS sensor and matching caliper is no more difficult than removing the other caliper and spacer.
bald1der
Aug 22, 2018 11:37 AM
Partsman116
Wheels/Tires
Feb 18, 2018 06:50 AM
Litewings
Jun 6, 2017 09:56 PM
Jaftica
Dec 15, 2015 08:41 AM
CSS899
May 19, 2015 12:24 PM
