Injectors
Old Sep 28, 2006 | 01:59 AM
Devil Dog's Avatar
Devil Dog
Default Injectors
I know this subject has been beat to death but I had to have my say. I started noticing things about the 06 SG that did not seem right. A little cough when starting, not running as well as she did when new, rough running engine. I went to the dealer and they said they checked it out and could not find anything amiss. It continued, I went back and asked them to look again. I "suggested" that maybe the injectors were bad. The boss in the shop said "I don't think that applies to SG's, only Softails." Hmm, I thought I remembered reading the bulletin which said any motorcycle with the 1450cc big twin. I am not the sharpest crayon in the box but wouldn't that include a Street Glide? Anyway, he called me later that evening and told me it was ready to be picked up. He said "we replaced the injectors". I don't know if that means they were bad or they just wanted to get me off of them. Now, it seems to run better and seems more peppy but the idle seems low. Yesterday it was about 700rpms at a traffic light. Today I was going to take it in and it was about 900-1000 rpms. Thinking it had something to do with being cool outside, I drove around for a half hour. It did not change, 900-1000 rpms. So, I guess it's ok. I sure hope so. Going for a trip this weekend.............................
Thanks for listening. Ride safe! Al.
Old Sep 28, 2006 | 08:39 AM
Bigredone's Avatar
Bigredone
Default RE: Injectors
Now go get a Powercommander, get it Dynoed and you are good to go.
Old Sep 28, 2006 | 09:27 AM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
ORIGINAL: Devil Dog
Devil Dog:
You are a sharp crayon, and apparently a sharper one then your service dealer.
All big twins (everything air cooled, less the sporties) are part of the bulletin. What it was regarding was if your bike was manufactured before 2/06, then you had 8° injectors. These injectors had a small amount of holes, like 3 or 4 I believe. The spray pattern was very small and the fuel did not atomize enough. Caused the bike to run rough, cough and sputter when cold. The fix was the MoCo would put 25° injectors in your ride. This injector has about 10 holes and the spray pattern was wider at 25°. The fuel was atomized better and bike will run stronger. These were the injectors that the MoCo put in the SE bikes originally. All bike produced after 2/06 had them installed as OEM.
Hope this helps you understand the issue better.
Now go get a Powercommander, get it Dynoed and you are good to go. (From Bigredone)
Ditto what he said. A custom map will get you the best results. I took a map from the PC website to start, but bike doesn't run as good as it should. Get a good PC dyno operator to dial you in. It's cheap money and is worth the $.
Denis
Old Sep 28, 2006 | 12:09 PM
SanJo's Avatar
SanJo
Devil Dog
Get the service bulletin and check the numbers on the injectors to make sure they actually changed them. My dealer lied and told me they changed them, only to find out all they did was put in some crappy download.[:@] Needless to say, another dealer actually DID the work and dealer #1 is history.
Old Sep 28, 2006 | 04:31 PM
Devil Dog's Avatar
Devil Dog
I checked..........they are the right ones, the 25 degree ones.
Old Sep 28, 2006 | 06:34 PM
Happy_dan's Avatar
Happy_dan
How can you tell what your build date is?
Old Sep 28, 2006 | 06:46 PM
oldfartjc's Avatar
oldfartjc
ORIGINAL: Happy_dan
The easiest thing to do is to just look at the rear injector from the left side of the bike behind the horn with a flashlight. If you have the 25° injectors it will say C01 25 DEG / 27709-06A on the body of the injector.
amervtwin
Apr 25, 2008 09:29 PM
Rocco18
Aug 4, 2007 07:36 PM
jpnelson1978
Jun 19, 2006 04:06 PM
johnnyig
Mar 29, 2006 08:49 PM
RED E GLIDE
Mar 27, 2006 01:42 AM
