Flushing brake lines
Old Dec 23, 2010 | 05:13 PM
slyder's Avatar
slyder
Default Flushing brake lines
Ive flushed brake lines with new fluid before but ive heard of people using denatured alcohol before. Is this a good practice or is there something else you can use?
Also Im getting ready to install Progressive Monotube Cartridges in my 99 FLHRCI and have a feeling its gonna be really nasty in those tubes....what should i flush the forks with?
Old Dec 23, 2010 | 06:54 PM
honestbob's Avatar
honestbob
Unless the brake fluid was contaminated with water why would you change it? I had 10 years on my last bike with the original fluid.
Old Dec 23, 2010 | 07:02 PM
DTTJGlide's Avatar
DTTJGlide
Brake kleen works good on brake lines & probably on the forks also, it evaporates & doesn't leave a residue.
Old Dec 23, 2010 | 07:20 PM
slyder's Avatar
slyder
I just upgraded my 99 rear swingarm with a 2006 model and the 06 caliper to go with it and also replaced the brake line (cause mine had a bad spot where it rubbed on the floorboard bracket).........the fluid was .....well....it looked like used motor oil. Strange since the fluid I put in was purple!
Old Dec 23, 2010 | 07:44 PM
tincup64's Avatar
tincup64
serious? wow - thats a new one for me. your probably right. i flush every couple of years on my motorcycles, but come to think of it - i never think of doing it with my cars. hmm. this will get me thinking.
as far as cleaning the sliders, just did mine and i 2nd brakekleen. that stuffs great. even the more environmentaly friendly green one.
tin
Old Dec 23, 2010 | 07:46 PM
slyder's Avatar
slyder
Yeah brake fluid is relatively cheap. Even if its not necessary......its worth the peace of mind.
Old Dec 23, 2010 | 09:55 PM
DTTJGlide's Avatar
DTTJGlide
Make sure your brake fluids are compatible, I'm not sure if MOCO changed from Dot 5 to Dot 4 in 06 or 07. Hopefully it was in 07 since you used Dot 5, purple color, otherwise you can have major problems since they definitely don't mix. I'm pretty sure it was 07, but you might want to check with somebody to be sure, I know it was talked about on an earlier post, but not sure what you'd want to search for to find it.
Old Dec 23, 2010 | 09:59 PM
slyder's Avatar
slyder
my bikes a 99. I swapped swingarms for an 06 model and an 06 caliper.
Mohammed Alyahya
Apr 11, 2019 03:21 PM
Billyjax
Wheels/Tires
Jan 6, 2012 06:02 PM
FastHarley
Wheels/Tires
11
Apr 10, 2010 09:50 AM
worthymccormick
Jan 29, 2010 08:53 AM
neverdown
Wheels/Tires
Jun 5, 2009 09:57 PM
