Brake Bleed vs Brake Flush
Old Jan 6, 2012 | 07:18 AM
Billyjax's Avatar
Billyjax
Default Brake Bleed vs Brake Flush
I have an 06 Deluxe. Don't know if brake fluid has ever been replaced/changed since 06.
Do I need to flush or will just bleeding them be ok?
Thanks
Old Jan 6, 2012 | 09:46 AM
JohnFlorida's Avatar
JohnFlorida
flush
Old Jan 6, 2012 | 04:25 PM
grbrown's Avatar
grbrown
They are much the same, flushing being bleeding until fresh fluid comes through. If you have a bike that is new to you flushing would be a wise thing to do.
If it uses DOT5, the factory fluid is a blue/violet colour when new, but turns a pale yellow as it gets old, eventually turning plain dirty! If it is yellow or worse, flushing is definitely the right thing to do!
Old Jan 6, 2012 | 04:27 PM
mi2az's Avatar
mi2az
The brake oils is pretty cheap. Just flush the thing out
Old Jan 6, 2012 | 05:58 PM
Morris9982's Avatar
Morris9982
Bleeding generally means getting any air out of the system and could mean just a couple pumps of the brakes.
Flushing means pushing fresh fluid through the whole system to ensure all the old fluid is replaced with fresh.
Flushing the system every two years is part of the maintenance schedule on my bike.
Old Jan 6, 2012 | 06:02 PM
gtrb's Avatar
gtrb
Active Streak: 120 Days
The older the brake fluid is, the more condensation can accumulate. Flush the system. It's easy and cheap maintenance.
Mohammed Alyahya
Apr 11, 2019 03:21 PM
c-note
Sep 30, 2018 05:13 PM
slyder
Dec 23, 2010 09:59 PM
rlchristensenmd
Wheels/Tires
Sep 14, 2009 03:05 PM
duoglider
Oil Archive (no new posts)
Jul 8, 2009 05:42 PM
