Picky Picky
Old Dec 28, 2010 | 08:39 PM
  #71
kwoozn's Avatar
kwoozn
For fear I don't shut it off right......
Not sure if I even want to start mine now?!
Which I suppose could lead to the forums next interesting debate: Been wondering, "how do you start your bike?"
Old Dec 28, 2010 | 10:48 PM
  #72
Zoomin Ultra's Avatar
Zoomin Ultra
From a safety standpoint, keeping both brakes applied during the shutdown process makes a lot of sense, so I use the kill switch.
I also use the kill switch every time, because it's another thing a thief will have to figure out before he can ride off.
As for the reverse emf's, that's so intuitively obvious it's weird someone actually thought it necessary to bring it up.
Old Dec 28, 2010 | 10:51 PM
  #73
PNSHVL's Avatar
PNSHVL
I always use the ignition, never the kill switch. I thought that was for emergencies only?
Old Dec 29, 2010 | 06:13 AM
  #74
dlrshort's Avatar
dlrshort
Taught to use the kill switch in the safety course but danger is to leave ignition on and drain the battery.
Old Dec 29, 2010 | 09:47 AM
  #75
Quadancer's Avatar
Quadancer
While Arty may have a point to concede, that would be for you guys with EI - I sincerely doubt that the ignition module on carbed models is prone to EMF failure; they've been around a very long time on many bikes without failing, and many English bikes didn't even HAVE a kill switch, nor choppers. The ECU may definitely be a different animal.
Mine is carbed and I use the ignition switch - but will shut off the fuel, kill switch, lock the ignition and front end and all available tactics if I have to leave the vicinity of the bike.
Heck, it takes ME a few minutes to get going!
Old Dec 29, 2010 | 11:17 AM
  #76
JonnyD's Avatar
JonnyD
Originally Posted by Wanna Ride
Seriously? Six pages back and forth of this?
Don't you just love this place
Old Dec 29, 2010 | 11:58 AM
  #77
peddler's Avatar
peddler
See attached!
Old Dec 29, 2010 | 12:18 PM
  #78
vickers1's Avatar
vickers1
Kill switch never.
Old Dec 29, 2010 | 12:35 PM
  #79
AR-15 DEUCE's Avatar
AR-15 DEUCE
never have used the kill switch...
Old Dec 29, 2010 | 01:53 PM
  #80
happyfeet's Avatar
happyfeet
Originally Posted by Lonewolf176
How about a data log that shows the ecm remembers 7.7% TPS% @ 0 rpm from a TBW bike that has been using the kill switch to shut off the bike? The reading should be 5%, which is what the ecm actually uses for 0. It also shows a higher TPS voltage than it should.
Not to start a discussion about how to start your bike but on a similar note, you should not touch the throttle on a TBW bike when you start it. I was having problems and that turned out to be the cause. There is a sequence of turning it on and off that resets the throttle position.
