V-Thunder Valva Ride Stabilizer
Old Dec 28, 2010 | 03:18 PM
3/4 life crisis's Avatar
3/4 life crisis
Default V-Thunder Valva Ride Stabilizer
Hello all,
Has anyone try this? Comments?
http://www.phatperformanceparts.com/...18&click=37735
After adding the Progressive stabilizer, definitely feel more vibration, especially @ idle. Will the above "tame" it down a little. I think these replace the stock motor mounts to the frame. Or since my '08 is a rubber mount anyway, would these do any good, or ill effects?
Thanks in advance. Ride safe.
Old Dec 29, 2010 | 08:35 AM
3/4 life crisis
Anyone?
Old Dec 29, 2010 | 08:55 AM
mongomark's Avatar
mongomark
I went with the Velva ride urethane front engine mount and it reduced the vibration significantly, almost to stock levels. That's what I had to go with in order for the progressive stabilizer to be tolerable.
Old Dec 29, 2010 | 12:58 PM
3/4 life crisis
Thank you for the reply, these look like tiny shock absorbers, different from the urethane engine mount. That's another thought though.
BTW, the original link no-workie, try this:
Old Dec 30, 2010 | 12:56 PM
Progressive Suspension's Avatar
Former Sponsor
Pretty rare we hear of the Touring Link inducing vibration and when we do it's almost always because the washer under the connecting rod is missing or the rod is mounted backwards. Both of which could allow the connecting rod to touch the brackets and induce vibration. Take a quick look, there should be a flat washer between the connecting rod and the supplied bracket and the connecting rod should be mounted with the visible threaded end on the trans bracket.
JVDeuce
Aug 5, 2012 01:49 AM
Scouser1
Apr 14, 2012 08:09 AM
Stiggy
Apr 11, 2011 06:52 PM
Dell
Nov 22, 2008 09:13 PM
Crusher
Mar 22, 2008 10:35 AM
