Tru track vibration
Old Aug 3, 2012 | 07:46 AM
JVDeuce's Avatar
JVDeuce
Default Tru track vibration
Had the TrubTrack installed on my LowRider and it corners and tracks much better. However, it seems to resonate the engine vibration through the frame and the ride is rougher. The wife picked up on it in the first mile. Is this common?
Old Aug 3, 2012 | 08:09 AM
mrlexus's Avatar
mrlexus
I did have that same suspicion with mine when I put in a sputhe. I thinks it does. Just forget about it and ride.
Old Aug 3, 2012 | 09:07 AM
secondlook's Avatar
secondlook
No its not suppose to, my front mount was out of alignment. Had the shop re-adjust it and you'll be all set! I had my mechanic call true-track and took care of in 5min
Old Aug 3, 2012 | 11:44 AM
Mike Horrell's Avatar
Mike Horrell
Yes; it's either slightly out of alignment or the link(s) are not adjusted properly.
Old Aug 3, 2012 | 12:35 PM
Robottom's Avatar
Robottom
There is also an adjustment bolt in the front mount that could be too close to its stop. Very easy to adjust if you want to look at that yourself. Here's the installation sheet showing the adjustment.
Old Aug 3, 2012 | 12:37 PM
07bobber's Avatar
07bobber
Did you replace the motor mounts at the same time?
Old Aug 5, 2012 | 01:49 AM
JVDeuce's Avatar
JVDeuce
Didn't replace the motor mounts as they were checked by the Indy mechanic who installed the Tru Track. I'll check the alignment tomorrow. Good input guys!
Yosemite
Apr 4, 2012 10:24 AM
3/4 life crisis
Dec 30, 2010 12:56 PM
Gummiente
Oct 28, 2010 11:54 AM
Crusher
Mar 22, 2008 10:35 AM
Rocket350
Sep 7, 2007 07:34 AM
