Just installed the Bright Axx tail light today on my EG...... Man, what a difference, however I did not choose the brightest option or the wildest brake pattern, that the light has to offer.... You use a magnet to change the intensity of the light and the sequence of flash pattern... I could see where some of the intensity levels and the flash patterns could be disturbing to a cage or bike that follows you........ One thing for sure... you will be seen when you brake and thats a good thing........ hdman
Don't worry it being "disturbing" to a cage..
I believe that was the intention of BAL to be seen.
Did your's come with the foam cover on the inside of it, or?
When I bought mine, which incidentally was one of the first mods I did, it did not have the stock foam inside covering that the original had so I contacted BAL and they sent me one.
I run Hyperlite's brake turn signal combo unit mounted on their license plate bracket. Twas a **** ton cheaper than buying the BAL. Had a similar Hyperlite setup on my 04
I'm a firm believer in being seen and heard..
lionsm,
Mine had the sticky peal foam cover... Real good seal for the unit. Fit and
finish of this USA product was first class. 5 year warrantly aint bad either....
hdman
I put the HD taillights and turn signal that operate as brake lights also on mine. I also put Custom Dynamics 96 led boards in my tour pak lights. I think Stevie Wonder can see me now.
That was the first mod that I made to my RK when I bought it in April. I think it's well worth the money, especially now when the weather gloomy and it gets dark earlier. A tap of my brakes gets the attention of the momos behind me.
