Question about Running "Lean"
Old Jan 2, 2011 | 03:52 PM
Mike T's Avatar
Mike T
More fuel works to help keep cylinders cool.
nsp261's Avatar
nsp261
Default Question about Running "Lean"
I am not a mechanic, I can do maintenance such as change fluids, filters, plugs, etc.
My question for someone in the know is this, why does an engine run "hot" when it is running lean? I don't have a real reason to ponder this because right now my 2004 Ultra is fully stock so it probably doesn't matter to me. I just want to know.
Old Jan 2, 2011 | 03:56 PM
TexasGrad83's Avatar
TexasGrad83
Check out this site for a good explanation on engine heat: http://www.nightrider.com/parts/hd2007hd_heat_00.htm. The XIED really works on cooling down the engine, and it's not too expensive...
Old Jan 2, 2011 | 03:58 PM
useR 564357348's Avatar
useR 564357348
An air cooled motor receives approx. 30% of it's cooling from fuel.
Old Jan 2, 2011 | 07:24 PM
Harleypingman's Avatar
Harleypingman
Your stock '04 doesn't have the heat issue that is so common now. HD started leaning out fuel in '07 for EPA compliance thereby creating an aftermarket industry to address the heat created by leaner fuel delivery.
Carl
Old Jan 2, 2011 | 09:10 PM
FDHOG's Avatar
FDHOG
Just think of it this way...The more oxygen you give a fire, the hotter it gets. Fuel just keeps it going.
Old Jan 2, 2011 | 09:55 PM
honestbob's Avatar
honestbob
#2 on the Nightrider IEDs I've had mine on for 70,000 miles now , no problems and runs a lot cooler.
Old Jan 3, 2011 | 11:08 PM
RK4ME's Avatar
RK4ME
If your '04 is stock, it's running too lean; maybe not enough to damage the engine but enough to affect performance. You can keep the stock mufflers and still get significant gains from a low restriction air cleaner and fuel minder like the Dyno Jet Power Commander III or V. I know because that's what I did for my '04 FLHRI with a PC V and map from Fuel Moto.
bbqbrisket
Jun 25, 2013 08:25 AM
The Cheesehead
Jul 15, 2012 11:36 AM
Pi-UNIT
Dec 28, 2009 07:56 AM
spizzyman
Sep 16, 2008 10:30 AM
2008FLHP
Dec 30, 2007 10:37 PM
