removing painted line on tire side wall?
Old Jan 3, 2011 | 08:14 PM
azbob09's Avatar
azbob09
Default removing painted line on tire side wall?
I just got a new FLHTK & didn't notice when I picked it up from the dealer that there was a painted yellow line, about 3/16 wide around the circumference of the tire about an 2 1/4 inches or so further out than the small white wall. Right about where the tire would make contact with the pavement if you really lean it into a corner. I called the dealer to ask why it was there & how to remove it. The service mgr. didn't no the reason for it but recommended using CRC Brakleen brake parts cleaner to remove it & said it wouldn't hurt the tire or create a slick spot. I tried it in a small spot & it did take the line off but I'm still worried about loosing traction like when using a side wall cleaner like armorall & the resulting crashes I've heard about other guys having.
Any experience or idea's with a problem like this???
I also put a call into CRCs tech. support but haven't heard back from them.
Old Jan 3, 2011 | 08:56 PM
jthom33's Avatar
jthom33
I have used Westleys Bleech White for cleaning sidewall tires on cars. When dry, there is no residue, just clean rubber. Good Luck.
Old Jan 3, 2011 | 09:06 PM
ripper43's Avatar
ripper43
Just ride it, it will come off soon enough.
Old Jan 3, 2011 | 09:11 PM
smithbrl's Avatar
smithbrl
Ride it off.
piasspj's Avatar
piasspj
I don't like armor-all and it isn't a cleaner but I've never heard of anyone crashing because of using it on the tires either.
I use SOS pads or plain old cleanser on the tires. Cleans up the WW and will take off the stripe your wanting to get rid of. Brake cleaner is strong stuff, I don't use it on anything other than brakes.
Old Jan 3, 2011 | 09:16 PM
FDHOG's Avatar
FDHOG
Armor All makes plastic and rubber surfaces SLICK. I would never use it on Motorcycle tires, but that's just me.
Old Jan 3, 2011 | 09:25 PM
2black1s's Avatar
2black1s
The brake cleaner should not be a problem. It won't leave any residue. Lacquer thinner is another good choice.
Armor All or anything similar is not a good choice. If it doesn't evaporate quickly, or leaves any residue, stay away from using it.
Old Jan 4, 2011 | 05:12 PM
MasterGuns(Ret)'s Avatar
MasterGuns(Ret)
A friend dumped his bike last year after his daughter did Daddy a favor by armor all'ing his tires all over. Boy was he pi$$ed. He had just finished getting it to where he wanted it too.
Smash
Sep 4, 2013 07:28 AM
SeniorChief56
Sep 1, 2013 02:35 PM
lupner1
Detailing
Feb 9, 2012 08:29 PM
DaddyKnuck
Jul 10, 2010 11:41 AM
23beatle
Detailing
21
Jun 25, 2009 12:06 PM
