I have an Ultra Limited. Up until recently starting it up was not an issue. The past two weeks after the bike has sat in my garage for a week or so I had to crank it 4-5 long cranks to get it started. I thought the problem may be moisture in the gas tank, but last week when I turned the bike off after a 15 mile ride and the bike was still warmed up, I had the same problem trying to start it up. Once started the bike runs fine. I have not yet made any modifications to the exhaust or a Stage One. The battery is fine as are all connections.
Do you think the problem might be moisture in the gas tank? The dealer thinks so. I plan on putting in some fuel stabilizer or something that can absorb any moisture in the tank and also putting on HD's platinum plugs.
Any other thoughts on what may be causing this condition other than moisture? Any thoughts on what else I should try?
Thanks in advance.
Since I have only started riding my bike on the weekends, instead of everyday, mine does the same, but I just hold the switch until she fires up. Sometimes it is 1-2 seconds, sometimes almost 5 seconds. Once I ride for quite a while, she will fire up like normal. I am just assuming it is the battery, since it sits there all week, plus the drain of the security system. Unfortunately, I park under a cover in a parking lot, so I do not have the luxury of keeping a tender hooked up to her. I return to the states in a little over 6 months, I will start plugging a tender up then.
