It finally came out part number 812-511 power commander for 07 touring models , talked to customer service friday says available now. Any one want to buy a vance & hines fuel pak ?
Doc - There is nothing special about your 110 as far as the PC is concerned. As far as I know, they have never had separate part numbers for the various engine displacements. If I were you I would put one on there as soon as possible, regardless of the pipes. You should be able to get a MAP that is very close to your current set-up preset in the PC from Fuel Moto. Once you get the pipes, I would recommend a dyno tune to get it spot on. The pre-canned MAP with stock exhaust should wake it up a little.
Thx Biggzed....I planned on it just wasn't sure on the maps that were out there yet.
