I hope you didn't learn the 2 finger technique in your MSF course. In the advanced course they teach you to use all of your fingers and to firmly squeeze the front brake. You have very little strength in two fingers compared to using all four. I also doubt you locking up the front wheel is going to put you in danger. In the advanced course they have you go 20 mph and squeeze it hard as you can. When balancing that with the rear brake there are no major issues.
Not pointing two fingers - just sayin'!
I'd like to respectfully disagree...
1) If two fingers on the brake lever is what feels right to you, then it's probably ok regardless of what some class may teach. There's usually more than one way to get the same result. I've been doing two-finger braking for years. In addition, I feel two fingers on the brake lever and the remaining two on the throttle give you better overall control. It makes it much easier to blip the throttle and downshift while still maintaining your braking. Kinda like the heel-toe method in a car.
2) Paraphrased... "Locking the front wheel is not going to put you in danger???" Are you kidding me? Locking up a front wheel is one of the scariest things that can happen on a bike! Now I haven't been doing this for years (luckily) but it did happen to me once on a Honda Interceptor slowing from about 115mph. As I was slowing in a straight line the front wheel locked at about 75-80 mph and in an instant, without any twitch or warning, I was on the ground.
3) Although you can get away with it in certain conditions on an ABS bike, I don't think it is ever appropriate to apply any brake, front or rear, as hard as you can. There's a feel you need to have.
Agreed. I'm so used to covering the brakes with two fingers that I find it uncomfortable to ride any other way. It's my own pet theory that the decreased reaction time more than makes up for any loss in sqeazing power, anyway. I'll also say that I've never been in a braking situation where my index and middle fingers weren't enough.
I always use both brakes when I use my brakes,,even at stop lights ,,might be a habbit from my raceing days,,,but ,,If you use both brakes everytime you use your brakes it will become a habbit,,and you will have better controlled braking...
Like said before, there aren't dual rotors up front for looks...and WTF locking the front isn't going to put you in danger??!! With all due respect, Sir, if I'm gonna lock one up, it sure as hell better be the back!
70 percent of your brekaing power is with your front brake. Being an old motocrosser I always used two fingers as it was more important to control the bike. MSF course taught me that you must use four fingers as breaking power is as stated 70% of your power. Thus using two finger as opposed to four reduces that 70 to maybe 50 or less?
There is no way 2 fingers are as strong as 4. You can still cover your throttle with your palm. Its bad karma to argue and debate these things so ride safe any way you see fit
